Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Power off your iPhone before beginning disassembly.
Remove the two 3.4 mm pentalobe screws on the bottom edge of the iPhone.
53 outras pessoas executaram este guia.
5 comentários
are there any water seals associated with the pentalobe screws? I blew compressed air into my iphone 7 and two tiny square rubber gaskets (~3mm) popped out. They squares have a round hole in them. I can only figure they are part of the pentalobe screw water seals, but I’m not sure, and I don’t know how to put them back in the phone to restore the water seal. Can anyone offer a solution?
@ataterka The screws themselves have a tiny ring-shaped rubber gasket on them. The two rubber squares you found slip onto the screw bosses. I don’t think those are needed for water sealing, and they’re not even included on newer models.
Does iPhone 7 and iPhone 8 (including «Plus» models) share the same bottom pentelope screws?
Put new lcd on with no problems then later batter went bad got new battery and can not get the 2 pentathlon screws out they loosen but not come out will tighten back up lossen but still want come out
How do I get screws out
