Ir para o conteúdo principal
iPhone 7 Pentalobe Schrauben austauschen
O que você precisa
  1. iPhone 7 Pentalobe Schrauben austauschen, Pentalobe Schrauben: passo 1, imagem 1 %32
    • Vor dem Beginn sollte der Akkuladestand des iPhones unter 25 % liegen. Ein geladener Lithium-Ionen Akku kann bei Beschädigung Feuer fangen oder explodieren.
    • Schalte das iPhone aus, bevor du es zerlegst.
    • Entferne die zwei 3,4 mm Pentalobe Schrauben an der Unterkante des iPhones.
    • Beim Öffnen des Gerätes werden die Dichtungen für den Spritzwasserschutz beschädigt. Halte Ersatzdichtungen bereit, bevor du fortfährst. Wenn du diese nicht ersetzt, ist dein Gerät nach der Reparatur nicht mehr gegen Spritzwasser geschützt.
Conclusão
Arbeite die Schritte in umgekehrter Reihenfolge ab, um dein Gerät wieder zusammenzubauen.
53 outras pessoas executaram este guia.
Um agradecimento especial a esses tradutores:
en de
100%
Estes tradutores estão nos ajudando a consertar o mundo! Quer contribuir?
Comece a traduzir ›
Evan Noronha
Membro desde: 02/05/15
223.406 Reputação
Autoria de 168 guias
5 comentários
are there any water seals associated with the pentalobe screws? I blew compressed air into my iphone 7 and two tiny square rubber gaskets (~3mm) popped out. They squares have a round hole in them. I can only figure they are part of the pentalobe screw water seals, but I’m not sure, and I don’t know how to put them back in the phone to restore the water seal. Can anyone offer a solution?
Austin Taterka - Responder
@ataterka The screws themselves have a tiny ring-shaped rubber gasket on them. The two rubber squares you found slip onto the screw bosses. I don’t think those are needed for water sealing, and they’re not even included on newer models.
Jeff Suovanen -
Does iPhone 7 and iPhone 8 (including «Plus» models) share the same bottom pentelope screws?
Victor Rezai - Responder
Put new lcd on with no problems then later batter went bad got new battery and can not get the 2 pentathlon screws out they loosen but not come out will tighten back up lossen but still want come out
Jerry Bonner - Responder
How do I get screws out
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 9
Últimos 7 dias: 31
Últimos 30 dias: 157
Duração total: 38,370
