Ir para o conteúdo principal
Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
iPhone 7 Display Assembly Replacement
Pré-requisito somente
Este guia destina-se apenas a ser usado como pré-requisito para outros guias. É incompleto por si só.
O que você precisa
  1. iPhone 7 Display Assembly Replacement, Display Assembly: passo 1, imagem 1 %32 iPhone 7 Display Assembly Replacement, Display Assembly: passo 1, imagem 2 %32 iPhone 7 Display Assembly Replacement, Display Assembly: passo 1, imagem 3 %32
    • Make sure the battery is disconnected before you disconnect or reconnect the cables in this step.
    • Use a spudger or a fingernail to disconnect the two lower display connectors by prying them straight up from their sockets on the logic board.
    • To reconnect these cables, press down on one end until it clicks into place, then repeat on the opposite end. Do not press down on the middle. If the connector is even slightly misaligned, the connector can bend, causing permanent damage.
    • If you have a blank screen, white lines on the display, or partial or complete lack of touch response after reassembling your phone, try disconnecting and carefully reconnecting both of these cables and make sure they are fully seated.
  2. iPhone 7 Display Assembly Replacement: passo 2, imagem 1 %32 iPhone 7 Display Assembly Replacement: passo 2, imagem 2 %32 iPhone 7 Display Assembly Replacement: passo 2, imagem 3 %32
    • Remove the two 1.3 mm Phillips #000 screws securing the bracket over the front panel sensor assembly connector.
    • Remove the bracket.
  3. iPhone 7 Display Assembly Replacement: passo 3, imagem 1 %32 iPhone 7 Display Assembly Replacement: passo 3, imagem 2 %32
    • Disconnect the front panel sensor assembly connector from its socket on the logic board.
    • This press connector should also be reconnected one end at a time to minimize the risk of bending.
  4. iPhone 7 Display Assembly Replacement: passo 4, imagem 1 %32
Conclusão
4 outras pessoas executaram este guia.
Evan Noronha
Membro desde: 02/05/15
223.427 Reputação
Autoria de 168 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 2,652
