Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
Follow the steps in this guide to replace the power button cover in your iPhone 6s Plus. This guide is only to replace the external power button cover, not the physical switch. If the button cover on your phone is undamaged but the power button does not work, you can follow this guide to replace the power switch underneath the button cover.
O que você precisa
Power off your iPhone before beginning disassembly.
Remove the two 3.4 mm Pentalobe screws on either side of the Lightning port.
Ferramenta utilizada nesse passo:Anti-Clamp$24.95
If you don't have an Anti-Clamp, follow the next three steps to use a suction handle.
Apply mild heat to the lower edge of the iPhone using an iOpener or hair dryer for about a minute.
Gently grasp the display assembly and lift it up to open the phone, using the clips at the top of the front panel as a hinge.
Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
Ferramenta utilizada nesse passo:Magnetic Project Mat$19.95
Remove two Phillips screws securing the battery connector bracket to the logic board, of the following lengths:
One 2.9 mm screw
One 2.3 mm screw
Remove the following Phillips screws:
Three 1.3 mm screws
One 1.6 mm screw
One 3.0 mm screw
Insert a SIM eject tool into the hole in the SIM tray.
Press to eject the SIM tray.
Remove the single 1.4 mm Phillips screw holding the NFC bracket in place.
Remove the following four Phillips screws:
Three 2.0 mm screws holding the power button bracket in place
One 1.3 mm Phillips screw over the flash and microphone bracket
Gently nudge the power button cover out of its slot in the rear case.
9 outras pessoas executaram este guia.
Um comentário
Hi,
I have done all the process, I have replaced the power button, but this does not fix the “no clicking” button issue.
Should I replace the power flat cable too? Or could it be related about how power button is inserted in the hole?
My power button flat is “clicking” if I try it with my nail, but I don’t know if this is enought clicking or it has got too much use..
