Introdução
Es wird gezeigt wie man das Glas des iPhone 6s Display ersetzt. Diese Anleitung ist eine Anleitung für Fortgeschrittene mit entsprechender speziellen Ausrüstung. Benutze diese wesentlich einfachere Anleitung, um den Bildschirm deines iPhone 6s zu ersetzen.
O que você precisa
Wenn du herausfinden möchtest, wie du dein iPhone 6s Displayglas ersetzen kannst, folge der mitgelieferten Anleitung. Im Falle von Problemen kannst du gerne Fragen stellen.
Um das iPhone wieder zusammenzusetzen, folge den Schritten in umgekehrter Reihenfolge.
7 outras pessoas executaram este guia.
Um agradecimento especial a esses tradutores:
100%
Estes tradutores estão nos ajudando a consertar o mundo! Quer contribuir?
Comece a traduzir ›
6 comentários
Do you have some equipment?
will a heat gun work?
or maybe I could rig up my hair straightener... What temp is that heat set at? I really like the way you cut the glue. Is that beading wire or fishing line? smart though!
Perhaps you can find a video in which the camera man doesn’t shoot the back of the technician’s hand when he’s accomplishing the critical step in the disassembly.
Beautiful work!
Would have been better if the repair had been done on camera!! Some of the removals were off screen and the start where the hinged unit was removed, what was going on there? Still images may have been a a help,
Colm - Responder
Ur kidding me right. Can’t see half of what he’s doing. Replace this with an actual help video.
Wayne - Responder
I cant even view the guide steps!
Tracey Homeward - Responder
