Ir para o conteúdo principal
iPhone 6s Battery Replacement
Guia arquivado
Este guia é mantido exclusivamente para fins históricos. Use a versão atualizada do guia para executar o reparo.
O que você precisa
  1. iPhone 6s Battery Replacement, Battery Connection: passo 1, imagem 1 %32
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.4 mm Pentalobe screws surrounding the Lightning connector.
  2. iPhone 6s Battery Replacement: passo 2, imagem 1 %32
    Ferramenta utilizada nesse passo:
    iSclack
    $24.99
    Comprar
    • If you don't have an iSclack, use a single suction cup to lift the front panel:
    • Press a suction cup onto the screen, just above the home button.
    • Be sure the cup is pressed securely onto the screen to get a tight seal.
  3. iPhone 6s Battery Replacement: passo 3, imagem 1 %32 iPhone 6s Battery Replacement: passo 3, imagem 2 %32 iPhone 6s Battery Replacement: passo 3, imagem 3 %32
    • There is a notch on the underside of the display just above the headphone jack that is the safest place to begin prying the phone open.
    • Pull up on the suction cup to slightly separate the front panel assembly from the rear case.
    • Take your time and apply firm, constant force. The display assembly is a much tighter fit than most devices and is held down with adhesive.
    • Once a small gap has been opened, insert the flat end of a spudger above the headphone jack.
  4. iPhone 6s Battery Replacement: passo 4, imagem 1 %32 iPhone 6s Battery Replacement: passo 4, imagem 2 %32
    • Twist the spudger to open the gap more and break it free from the adhesive.
    • Keep pulling up on the suction cup while twisting the spudger.
  5. iPhone 6s Battery Replacement: passo 5, imagem 1 %32 iPhone 6s Battery Replacement: passo 5, imagem 2 %32
    • Use the edge of a spudger to slice through the adhesive on either side of the phone.
  6. iPhone 6s Battery Replacement: passo 6, imagem 1 %32 iPhone 6s Battery Replacement: passo 6, imagem 2 %32
  7. iPhone 6s Battery Replacement: passo 7, imagem 1 %32 iPhone 6s Battery Replacement: passo 7, imagem 2 %32 iPhone 6s Battery Replacement: passo 7, imagem 3 %32
    • Use the suction cup to open the display, breaking the last of the adhesive.
    • Don't open the display more than 90 degrees, as it is still connected at the top by three cables that may break if stretched.
  8. iPhone 6s Battery Replacement: passo 8, imagem 1 %32
    • Lean the display against something to keep it propped up while you're working on the phone.
  9. iPhone 6s Battery Replacement: passo 9, imagem 1 %32
    • Remove the following screws from the battery connector bracket:
    • One 3.0 mm Phillips #00 screw
    • One 2.3 mm Phillips #00 screw
  10. iPhone 6s Battery Replacement: passo 10, imagem 1 %32
    • Remove the metal battery connector bracket from the iPhone.
  11. iPhone 6s Battery Replacement: passo 11, imagem 1 %32 iPhone 6s Battery Replacement: passo 11, imagem 2 %32 iPhone 6s Battery Replacement: passo 11, imagem 3 %32
    • Use the flat end of a spudger to disconnect the battery connector from the logic board.
    • Push the connector to the side to ensure it doesn't accidentally make contact and power on the phone while you're working on it.
  12. iPhone 6s Battery Replacement, Battery: passo 12, imagem 1 %32 iPhone 6s Battery Replacement, Battery: passo 12, imagem 2 %32 iPhone 6s Battery Replacement, Battery: passo 12, imagem 3 %32
    • Use tweezers to peel up the edges of the two adhesive strips at the bottom of the battery.
  13. iPhone 6s Battery Replacement: passo 13, imagem 1 %32
    • Grab the ends of the two adhesive strips and hold them together. Try to keep the strips flat and wide.
  14. iPhone 6s Battery Replacement: passo 14, imagem 1 %32 iPhone 6s Battery Replacement: passo 14, imagem 2 %32 iPhone 6s Battery Replacement: passo 14, imagem 3 %32
    • Slowly and gently pull the two strips up and away from the phone.
    • The strips will stretch to many times the length of the battery—keep pulling until they come out from between the battery and the rear case.
  15. iPhone 6s Battery Replacement: passo 15, imagem 1 %32
    • Remove the battery from the rear case.
    • When installing the battery, refer to this guide to replace your battery's adhesive strips.
Conclusão
75 outras pessoas executaram este guia.
Sam Goldheart
Membro desde: 10/18/12
465.744 Reputação
Autoria de 538 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 135
Autoria de 16.767 guias
11 comentários
Quickkkkkkkkkkk Question. How do I go about replacing that adhesive you had me slice?
Doc Brown - Responder
I need to buy the 6s replacement battery itself as well as the tools. Do you sell that as well as the display?
2ndwindranch - Responder
i remember i get my battery repair kit and adhesive for less than 25$ from this seller on amazon https://www.amazon.com/dp/B01LKN9AUG
exdany9 -
Please do a video. Lets see how fast you guys can change the 6s battery.
klactwiggy - Responder
nice very repair mizan.....
mohsen m - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 7
Duração total: 68,700
