Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Remove the following screws securing the antenna bracket to the rear case:
One 1.5 mm Phillips #00 screw
One 2.8 mm Phillips #00 screw
Grasp the antenna bracket with a pair of tweezers and lift it off the iPhone.
Carefully pry the antenna connector up off the logic board with a plastic opening tool.
Grasp the antenna connector with a pair of tweezers and gently lift it from its retaining clip on the logic board.
Disconnect the power button cable and audio control cable connectors from their respective sockets on the logic board.
Remove the following screws securing the top cellular antenna to the rear case:
Two 1.6 mm Phillips #00 screws
Use a pair of tweezers to grasp and remove the top cellular antenna out of the iPhone.
