Ir para o conteúdo principal
Introdução
Prereq only, battery removed.
Peças
Nenhum componente especificado.
  1. iPhone 6 Plus Antenna Assembly Replacement, Antenna Assembly: passo 1, imagem 1 %32
    • Remove the following screws securing the antenna bracket to the rear case:
    • One 1.5 mm Phillips #00 screw
    • One 2.8 mm Phillips #00 screw
  2. iPhone 6 Plus Antenna Assembly Replacement: passo 2, imagem 1 %32
    • Grasp the antenna bracket with a pair of tweezers and lift it off the iPhone.
  3. iPhone 6 Plus Antenna Assembly Replacement: passo 3, imagem 1 %32
    • Carefully pry the antenna connector up off the logic board with a plastic opening tool.
  4. iPhone 6 Plus Antenna Assembly Replacement: passo 4, imagem 1 %32 iPhone 6 Plus Antenna Assembly Replacement: passo 4, imagem 2 %32
    • Grasp the antenna connector with a pair of tweezers and gently lift it from its retaining clip on the logic board.
  5. iPhone 6 Plus Antenna Assembly Replacement: passo 5, imagem 1 %32 iPhone 6 Plus Antenna Assembly Replacement: passo 5, imagem 2 %32
    • The two connectors may be coupled by a single adhesive tab. If this is the case, then they may detach as a pair.
    • Disconnect the power button cable and audio control cable connectors from their respective sockets on the logic board.
  6. iPhone 6 Plus Antenna Assembly Replacement: passo 6, imagem 1 %32
    • Remove the following screws securing the top cellular antenna to the rear case:
    • Two 1.6 mm Phillips #00 screws
  7. iPhone 6 Plus Antenna Assembly Replacement: passo 7, imagem 1 %32 iPhone 6 Plus Antenna Assembly Replacement: passo 7, imagem 2 %32
    • Use a pair of tweezers to grasp and remove the top cellular antenna out of the iPhone.
    • During reassembly, make sure to place the small washer in the top left corner of the antenna assembly.
Conclusão
2 outras pessoas concluíram este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 1,028
