Ir para o conteúdo principal
iPhone 6 Pentalobe Screws Replacement
O que você precisa
  1. iPhone 6 Pentalobe Screws Replacement, Pentalobe Screws: passo 1, imagem 1 %32
    • Before disassembling your iPhone, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.6 mm-long P2 Pentalobe screws next to the Lightning connector.
Conclusão
100 outras pessoas executaram este guia.
8 comentários
What size screwdriver do I need to remove these screws?
ronrola - Responder
P2 Pentalobe Screwdriver
sbrown9615 -
really? follow these steps in reverse to reinstall? it already is laughably short...
beautron7 - Responder
also how is this moderate difficulty?
I have the correct screwdriver, but after taking out the original pentalobe screws, they will not screw back into the iPhone. Really bizarre. Do these screws get easily stripped?
dcs Bu - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 37
Últimos 30 dias: 144
Duração total: 64,590
