Ir para o conteúdo principal
iPhone 6 Home Button Replacement
Pré-requisito somente
Este guia destina-se apenas a ser usado como pré-requisito para outros guias. É incompleto por si só.
O que você precisa
  1. iPhone 6 Home Button Replacement, Home Button: passo 1, imagem 1 %32
    • Remove the two 1.9 mm Phillips screws securing the home button bracket.
  2. iPhone 6 Home Button Replacement: passo 2, imagem 1 %32 iPhone 6 Home Button Replacement: passo 2, imagem 2 %32
    • Remove the home button bracket from the front panel.
  3. iPhone 6 Home Button Replacement: passo 3, imagem 1 %32 iPhone 6 Home Button Replacement: passo 3, imagem 2 %32
    • Use the point of a spudger to disconnect the home button cable connector by pushing it up and away from the home button.
  4. iPhone 6 Home Button Replacement: passo 4, imagem 1 %32 iPhone 6 Home Button Replacement: passo 4, imagem 2 %32
    Ferramenta utilizada nesse passo:
    iOpener
    $19.99
    Comprar
    • The rubber membrane surrounding the home button is very thin and tears easily.
    • Apply mild heat (with an iOpener, heat gun, or hair dryer) to soften the adhesive securing the home button membrane.
    • Using your fingertip, apply firm, constant pressure on the home button from the front side of the display assembly, until the membrane starts to separate from the front panel.
    • Do not push the home button all the way through—you only need to get a corner free so that you can pry it free with a spudger.
  5. iPhone 6 Home Button Replacement: passo 5, imagem 1 %32 iPhone 6 Home Button Replacement: passo 5, imagem 2 %32
    • Peel the home button the rest of the way off of the display by prying gently with a spudger.
  6. iPhone 6 Home Button Replacement: passo 6, imagem 1 %32 iPhone 6 Home Button Replacement: passo 6, imagem 2 %32
    iOpener
    $12.99
    Comprar
    • Use the point of a spudger to carefully separate the home button cable from the adhesive securing it to the front panel.
    • If the cable doesn't separate easily, apply heat using an iOpener or hair dryer to soften the adhesive, and try again. Be careful not to damage the cable.
  7. iPhone 6 Home Button Replacement: passo 7, imagem 1 %32
    • Once all the adhesive has been separated, remove the home button from the front panel.
    • If you are replacing a broken front panel, there may be glass shards stuck to the home button. Carefully remove any remaining glass before transferring your home button to a new display.
    • Your replacement part may come with an extra Phillips screw already installed left of the Home Button. Remove the unnecessary screw so that you can reinstall the home button bracket.
Conclusão
9 outras pessoas executaram este guia.
Sam Goldheart
Membro desde: 10/18/12
465.777 Reputação
Autoria de 538 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 135
Autoria de 16.817 guias
Um comentário
Home button robin cable malfunction after replaced.
Replaced broken Home button robin cable, now the phone will not turn on unless I unplug the home button cable from the mother board! I've thought of placing the phone in recovery mode and placing the phone in factory setting then trying to reconnect the cable, BUT to do that the home button has to be WORKINGand it's NOT working. Also the phone as the current iOS on it... Any ideas other than buying a new home button cable and trying the replacement again?
Hector - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 6,038
