Introdução
prereq only (full home button guide includes removing gasket)
O que você precisa
Ferramenta utilizada nesse passo:iOpener$19.99
Apply mild heat (with an iOpener, heat gun, or hair dryer) to soften the adhesive securing the home button membrane.
Using your fingertip, apply firm, constant pressure on the home button from the front side of the display assembly, until the membrane starts to separate from the front panel.
9 outras pessoas executaram este guia.
Um comentário
Home button robin cable malfunction after replaced.
Replaced broken Home button robin cable, now the phone will not turn on unless I unplug the home button cable from the mother board! I've thought of placing the phone in recovery mode and placing the phone in factory setting then trying to reconnect the cable, BUT to do that the home button has to be WORKINGand it's NOT working. Also the phone as the current iOS on it... Any ideas other than buying a new home button cable and trying the replacement again?
