Ir para o conteúdo principal
iPhone 5c SIM Card Replacement
O que você precisa
  1. iPhone 5c SIM Card Replacement, SIM Card: passo 1, imagem 1 %32 iPhone 5c SIM Card Replacement, SIM Card: passo 1, imagem 2 %32
    • Shut your phone down completely before removing the SIM card and tray.
    • Insert a SIM card eject tool or a paperclip into the small hole in the SIM card tray.
    • Press the SIM card eject tool inwards to eject the tray.
    • This may require a significant amount of force.
  2. iPhone 5c SIM Card Replacement: passo 2, imagem 1 %32
    • Remove the SIM Card tray assembly from the iPhone.
    • During reassembly, ensure that the SIM card is in the proper orientation relative to the tray.
Conclusão
42 outras pessoas executaram este guia.
2 comentários
How would you replace the sim card try if the tray is jammed? Is there a way to open up the phone and replace it internally?
Patricia Lovera - Responder
You can try opening the phone and removing the SIM eject lever, or seeing if its obstructed somehow, with this guide. good luck!
Sam Goldheart -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 32
Duração total: 17,172
