Ir para o conteúdo principal
iPhone 5 Lightning Connector and Speaker Assembly Replacement
Pré-requisito somente
Este guia destina-se apenas a ser usado como pré-requisito para outros guias. É incompleto por si só.
O que você precisa
  1. iPhone 5 Lightning Connector and Speaker Assembly Replacement, Lightning Connector and Speaker Assembly: passo 1, imagem 1 %32
    • Remove the following screws securing the Lightning connector and speaker enclosure assembly to the rear case:
    • One 2.5 mm Phillips screw
    • Two 3.3 mm Phillips screws
    • One 2.9 mm Phillips screw
    • Two 1.5 mm Phillips screws
    • One 2.8 mm Phillips screw
  2. iPhone 5 Lightning Connector and Speaker Assembly Replacement: passo 2, imagem 1 %32 iPhone 5 Lightning Connector and Speaker Assembly Replacement: passo 2, imagem 2 %32 iPhone 5 Lightning Connector and Speaker Assembly Replacement: passo 2, imagem 3 %32
    • Use the flat end of a spudger to gently pry the Lightning connector and speaker enclosure assembly cables up from the rear case.
    • Make sure you get the spudger under the large ribbon cable connected to the assembly. Prying the rest of the assembly away from the cable may result in a tear.
  3. iPhone 5 Lightning Connector and Speaker Assembly Replacement: passo 3, imagem 1 %32 iPhone 5 Lightning Connector and Speaker Assembly Replacement: passo 3, imagem 2 %32 iPhone 5 Lightning Connector and Speaker Assembly Replacement: passo 3, imagem 3 %32
    • Remove the Lightning connector and speaker enclosure assembly from the rear case.
    • Take care not to lose the small metal washer on the speaker enclosure, or the four small metal washers beneath the Lightning connector screws.
Conclusão
Andrew Optimus Goldheart
Membro desde: 10/17/09
503.079 Reputação
Autoria de 407 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 136
Autoria de 17.299 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 12
Duração total: 1,819
