Ir para o conteúdo principal
Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
iPhone 4S Power and Sensor Cable Assembly Replacement
Pré-requisito somente
Este guia destina-se apenas a ser usado como pré-requisito para outros guias. É incompleto por si só.
O que você precisa
  1. iPhone 4S Power and Sensor Cable Assembly Replacement, Power and Sensor Cable Assembly: passo 1, imagem 1 %32 iPhone 4S Power and Sensor Cable Assembly Replacement, Power and Sensor Cable Assembly: passo 1, imagem 2 %32
    • Use the edge of a plastic opening tool to pry the earpiece speaker off the adhesive securing it to the outer case. Note that the power button cable is glued to the the case as well, and will need to be pried up.
    • Use a pair of tweezers to unfold the earpiece speaker from its recess in the outer case.
    • Be careful not to tear the cable from the earpiece speaker. They are adhered together, and the cable is very delicate.
  2. iPhone 4S Power and Sensor Cable Assembly Replacement: passo 2, imagem 1 %32 iPhone 4S Power and Sensor Cable Assembly Replacement: passo 2, imagem 2 %32
    • Use the edge of plastic opening tool to gently move the top sensor assembly away from the outer case.
    • Gently pry the top sensor assembly off the outer case.
  3. iPhone 4S Power and Sensor Cable Assembly Replacement: passo 3, imagem 1 %32 iPhone 4S Power and Sensor Cable Assembly Replacement: passo 3, imagem 2 %32 iPhone 4S Power and Sensor Cable Assembly Replacement: passo 3, imagem 3 %32
    • Lift and remove the power and sensor cable assembly from the iPhone.
    • Be sure not to lose the small retainer clip located on the top sensor assembly.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 862
