Ir para o conteúdo principal
iPhone 4S - Charging Dock Connector & Loud Speaker and WiFi Antenna Replacement
Guia arquivado
Este guia é mantido exclusivamente para fins históricos. Use a versão atualizada do guia para executar o reparo.
O que você precisa
Vídeo de Apresentação
  1. iPhone 4S - Charging Dock Connector & Loud Speaker and WiFi Antenna Replacement, Dock Connector: passo 1, imagem 1 %32
    • If present, remove the small strip of tape covering one of the dock connector screws.
  2. iPhone 4S - Charging Dock Connector & Loud Speaker and WiFi Antenna Replacement: passo 2, imagem 1 %32 iPhone 4S - Charging Dock Connector & Loud Speaker and WiFi Antenna Replacement: passo 2, imagem 2 %32
    • Use a plastic opening tool to flip up the retaining flap on the home button ribbon cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
  3. iPhone 4S - Charging Dock Connector & Loud Speaker and WiFi Antenna Replacement: passo 3, imagem 1 %32
    • Use a pair of tweezers to pull the home button ribbon cable out of its socket.
    • There are tiny components on the back side of the ribbon, so be careful not to damage them upon ribbon removal.
  4. iPhone 4S - Charging Dock Connector & Loud Speaker and WiFi Antenna Replacement: passo 4, imagem 1 %32
    • Carefully pull the rubber microphone holder out of its tube in the bottom edge of the iPhone.
  5. iPhone 4S - Charging Dock Connector & Loud Speaker and WiFi Antenna Replacement: passo 5, imagem 1 %32
    • Remove the two 1.3 mm Phillips screws securing the dock connector to the case of the iPhone.
  6. iPhone 4S - Charging Dock Connector & Loud Speaker and WiFi Antenna Replacement: passo 6, imagem 1 %32
    • Remove the tiny rubber spacer near the dock connector.
  7. iPhone 4S - Charging Dock Connector & Loud Speaker and WiFi Antenna Replacement: passo 7, imagem 1 %32 iPhone 4S - Charging Dock Connector & Loud Speaker and WiFi Antenna Replacement: passo 7, imagem 2 %32
    • Use the edge of a plastic opening tool to peel the dock connector and its cable off the black plastic case of the iPhone.
    • If you are replacing the dock connector with a new part, make sure to transfer the rubber casing around the microphone. You can do this using a spudger.
  8. iPhone 4S - Charging Dock Connector & Loud Speaker and WiFi Antenna Replacement: passo 8, imagem 1 %32 iPhone 4S - Charging Dock Connector & Loud Speaker and WiFi Antenna Replacement: passo 8, imagem 2 %32
    • Pry the dock connector away from its opening at the bottom of the iPhone.
    • Remove the dock connector.
  9. iPhone 4S - Charging Dock Connector & Loud Speaker and WiFi Antenna Replacement, Speaker Enclosure: passo 9, imagem 1 %32
    • Speaker enclosure remains.
Conclusão
19 outras pessoas executaram este guia.
ZFix
Membro desde: 12/09/13
191.308 Reputação
Autoria de 330 guias
Equipe
Master Techs Membro de Master Techs
Community
Membros da 322
Autoria de 2.532 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 10,623
