Ir para o conteúdo principal
iPhone 4 Speaker Enclosure Assembly Replacement
Pré-requisito somente
Este guia destina-se apenas a ser usado como pré-requisito para outros guias. É incompleto por si só.
O que você precisa
  1. iPhone 4 Speaker Enclosure Assembly Replacement, Speaker Enclosure Assembly: passo 1, imagem 1 %32 iPhone 4 Speaker Enclosure Assembly Replacement, Speaker Enclosure Assembly: passo 1, imagem 2 %32
    • Remove the following two screws:
    • One 1.2 mm Phillips
    • One 1.6 mm Phillips
    • Remove the thin steel dock connector cable cover from the iPhone.
    • Before reassembly, be sure to clean all metal-to-metal contact points on the dock connector cable cover with a de-greaser such as windex. The oils on your fingers have the potential to cause wireless interference issues.
  2. iPhone 4 Speaker Enclosure Assembly Replacement: passo 2, imagem 1 %32 iPhone 4 Speaker Enclosure Assembly Replacement: passo 2, imagem 2 %32
    • Use a plastic opening tool to gently pry the dock cable connector up off the logic board from both short ends of the connector.
  3. iPhone 4 Speaker Enclosure Assembly Replacement: passo 3, imagem 1 %32 iPhone 4 Speaker Enclosure Assembly Replacement: passo 3, imagem 2 %32
    • Carefully peel the dock ribbon cable off the logic board and the lower speaker enclosure.
    • Do not use excessive force to peel the dock ribbon cable off the logic board. Doing so may tear the cable.
  4. iPhone 4 Speaker Enclosure Assembly Replacement: passo 4, imagem 1 %32
    • Use a plastic opening tool to pry the lower antenna connector up off its socket on the logic board.
  5. iPhone 4 Speaker Enclosure Assembly Replacement: passo 5, imagem 1 %32
    • Remove the following screws securing the speaker enclosure assembly to the outer case:
    • One 1.9 mm Phillips screw
    • One 2.4 mm Phillips screw
  6. iPhone 4 Speaker Enclosure Assembly Replacement: passo 6, imagem 1 %32 iPhone 4 Speaker Enclosure Assembly Replacement: passo 6, imagem 2 %32 iPhone 4 Speaker Enclosure Assembly Replacement: passo 6, imagem 3 %32
    • Use a plastic opening tool to lift the speaker enclosure assembly out of the case, being sure not to damage the EMI fingers on the attached Wi-Fi antenna.
    • Remove the speaker enclosure assembly.
    • Before reinstalling the speaker enclosure assembly's screws, be sure the Wi-Fi grounding fingers are installed below the lip in the iPhone's metal case as seen in the third picture.
    • Before reassembly, be sure to clean all metal-to-metal contact points between the grounding fingers of the Wi-Fi antenna and the case of the iPhone with a de-greaser such as windex or isopropyl alcohol. The oils on your fingers have the potential to cause wireless interference issues.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 73
