Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Loja
Introdução
Be sure that you have the correct tools for the job. If not, make sure to get the right tools before starting.
Peças
Nenhum componente especificado.
  1. Here you can see the original cracked rear panel and the replacement panel. Next using a Phillips head screwdriver, remove the mounting screws at the bottom of the iPhone. Place them aside carefully as they are really small. Finally, once the screws are out gently apply pressure and slide the screen up to release the panel. Careful not to be too rough with it.
    • Here you can see the original cracked rear panel and the replacement panel.
    • Next using a Phillips head screwdriver, remove the mounting screws at the bottom of the iPhone. Place them aside carefully as they are really small.
    • Finally, once the screws are out gently apply pressure and slide the screen up to release the panel. Careful not to be too rough with it.
  2. SKIP THE UPGRADE
    Save by fixing with an all-in-one kit.
    Shop iPhone Fix Kits
    SKIP THE UPGRADE
  3. Carefully place the replacement panel on to the iPhone back lining it up as close to the bottom as possible. Now again gently apply pressure as you slide the panel towards the bottom of the iPhone to lock it into place.
    • Carefully place the replacement panel on to the iPhone back lining it up as close to the bottom as possible.
    • Now again gently apply pressure as you slide the panel towards the bottom of the iPhone to lock it into place.
    • Replace the screws that you set aside earlier and be sure no to over tighten otherwise you will strip them.
Conclusão
21 outras pessoas concluíram este guia.
Trekboy72
Membro desde: 12/08/2014
1.119 Reputação
2 Guias de autoria
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 7,261
