Introdução
Use this guide to replace your iPhone 4's logic board.
Vídeo de Apresentação
Power off your iPhone before beginning disassembly.
Your iPhone 4 rear cover may have either two #000 Phillips screws or Apple's 5-Point "Pentalobe" screws (second image). Check which screws you have, and ensure you also have the correct screwdriver in order to remove them.
Remove the two 3.6 mm Pentalobe or Phillips #000 screws next to the dock connector.
Push the rear panel toward the top edge of the iPhone.
If the back doesn't slide in properly upon reassembly, you didn't insert the motherboard properly. Remove it and try it again, DO NOT try to force it down!
Pinch the rear panel with your fingers and lift it away from the iPhone. Alternatively, use a Small Suction Cup .
using suction cup with too much force breaks rear panel
Remove the single 2.5 mm Phillips screw securing the battery connector to the logic board- for me this Phillips screw won't budge from its place have tried all the phillips combinations 000, 00, 0, 1 and the straight /slotted 1.5 mm but nothing. can some help me please purchased a replacement battery for my iPhone 4 but not able to do it just because of this screw.
If the screw head is not buggered, press the tip of a hot soldering iron to the screw for a second or two. Don't get it too hot, or you'll damage something.
splaye -
don't use hot soldering iron . the female outlet the battery plugs into is very fragile . for no extra money you can buy a battery that has magnetic tools specifically to pick this screw out . if worse comes to worse be certain the screw will come no looser then use tweezers and pick it out . the #1 fear with this technique is DO NOT DROP THE SCREW . I have done this and crawling on my hands and knees till I find it was depressing
Remove the single 2.5 mm Phillips screw securing the battery connector to the logic board.
I was going through the take apart and after reassembly, it seems to just sit there an power cycle. It's as though the battery is no longer working. Any thoughts as to what I may have done wrong?
you potentially messed up the ribbon cable from the battery to the adapter. I have done it before. Its not fun...
barri80 -
Stuck on step 4 can't unscrew the battery screw. stopped trying as all i seem to be doing is damaging the screw any tips as to how to approach this?
I ended up drilling the head of one of my screws off. It was already damaged. Then I think I used needle pliers to spin it out once the plate came off and there was more room to grab the shank.
I didn't need to remove the battery !! why would you take the battery away, the motor can be removed easily with the battery in place, and the whole process would take less than 2 minutes if you exclude the battery steps
I was VERY careful but the interior philips screw holding the battery in place but it stripped immediately. I see others have had this problem. What do I do now?!
I've tried three different #000 drivers but they don't fit this screw. Stuck now. Also blows my confidence about proceeding because even if I do get this off.... I see some even smaller Phillips head screw further along in the process
If the screw is not damaged by previous attempts, the screw driver should fit perfectly. You can also tap the screw with a small mass to unlock.
revher -
Use a plastic opening tool to gently pry the battery connector up from its socket on the logic board.
Remove the metal clip covering the antenna connector.
There is a small black L-shaped bracket of some sort that tits between the battery connector and the motherboard socket, with a loop on one corner that sits betwen the riserand the battery connector. Remove this now, and do not forget to re install it on assembly.
In Step 5 be EXTRA careful with the battery connector as the socket can come off extremely easy. This can mess up the replacement a little bit and cost you extra. Otherwise, this guide is excellent.
Good luck, fixers!
I fix(ed) it!
When removing this L shaped piece, it should be shown ON CAMERA where it came from and the exact position it was in while in the phone, I had to take 2 screws (not 1 like said in the video) out to get to this piece and once that second screw came up I didn't get a chance to see where this piece came from because it popped right out. I was extremely nervous but I believe I got it back in properly.
Putting the antennae cover back in place is impossible without a good photo. I used this link to refer to:
Use the clear plastic pull tab to gently lift the battery out of the iPhone.
If there's any alcohol solution remaining in the phone, carefully wipe it off or allow it to air dry before installing your new battery.
Before reconnecting the battery connector, be sure the contact clip (shown in red) is properly positioned next to the battery connector.
use the iPod opening tool to pry gently under the battery from the outer edge of the phone and work towards the plastic tab. the tab is not actually attached to the battery itself, but a plastic sheet between the battery and inner frame. the adhesive on the battery tends to be under the edge of the battery nearest the center of the phone.
This i think is the most diffucult part.
Because they use so much glue on it. I have to did this with so much force.
Glad that i didn't kill the circuit board when i took this out.
My battery was so firmly glued in, it took a long time to slowly pry it loose. Patience is the key to this process. I could see easily damaging the circuit board by using too much force. The plastic tab did not help at all.
The ribbon cable attaching the new battery to the battery connector clip is longer than the original. I clicked the clip into the socket first and then was very careful to fold the excess while putting the battery back in so the ribbon cable didn't kink. One kink in this could sever the battery leads.
My ribbon cable was also longer than the original. How did you get it to not kink while placing the batter back into the phone? That seems to be my only hang up at the moment
Piece of cake! The hardest part was being sure the outer pentalobe screws were actually turning and I wasn't stripping them. Battery was glued firmly in, so I loosened it from the outside instead of using the plastic pull-tab. I pre-bent the battery connector neck before putting it back in and had no problems with it fitting in. Getting the battery connector aligned with the antenna piece underneath was a bit fiddly. Got the case back on, put in the new screws, and powered the phone on without problem. Had 40% charge, all seems well. Yippee!
Do NOT use a spudger or similar type of prising tool to try lift up the battery. Instead, just warm up the whole area with a hot air gun or hair drier to soften the glue.
The reason why I say don't use an implement to try lift the battery is because far too many times I've seen punctured & bent batteries come in to this workshop that have to be thrown out for safety reasons. It only takes a grain of sand, or a burr on the spudger and you're risking a potential cell rupture and potential fire.
Just use a bit of heat ( not a lot! ) to soften up the glue and it'll come away with the plastic pull tab.
These instructions don't mention putting the 2.5mm screw back in. I found this very challenging because it is so short, so very difficult to line it up to get it back in the hole, and very easy to drop it inside the phone. Take care.
Apparently it's not necessary to remove the battery, but try at least (I'm curious).
The battery was stuck (too much glue) and the plastic tab didn't help, and I ripped it...
So I use the plastic opening tool on the other side to remove really gently the battery, it was really really stucked with the glue... Now I'll know when I'll need to change it.
I put a little piece of tape to repair the plastic tab for the next time.
For the other part of the guide, it was a piece of cake and I'm a bad bad handyman :)
Thanks for the guide!
You are right. This is the reason why their is simpler guide: iPhone 4 Battery disconnection to be used when there is no necessity for removing the battery. Disconnection is sufficient for many fixes except replacement of the battery!
revher -
you have to remove the battery for digitizer replacement, however i would suggest removing it at the very last stage, i.e. step 24. cause it is easier to remove without the logic board being there
Adhesive was holding battery VERY firmly, so during this step I used a hair blow dryer on low setting to carefully heat up the device. Then used the plastic tool to gently but firmly pry up one place on each edge. At first it felt like barely anything was happening, but within a few tries the adhesive gave away easily and the battery came right out.
Before inserting the battery I put the contact clip into position. It has a hooked shape on one side which fits between the socket and the folded battery cable. If you try to position it AFTER the battery is installed the whole process is much more difficult. I used a tweezers to hold it in place while inserting the battery.
When inserting the battery I started by guiding the folded cable into position against the side of the contact clip, then proceeded to lay the battery in position. This made it very easy to have all parts in their original positions -- no need to fiddle with the battery cable or contact clip afterwards.
When pressing the battery connector into the socket, the first time I pressed from bottom to top. That didn't work because there is a little tab at the top of the connector which must fit into a tiny notch or else the connector won't lay flat properly. Pressing the connector from top to bottom worked easily.
Needle-nosed tweezers were very helpful when lining up the screws. After everything was reassembled I tried powering up the device, but the battery had insufficient charge. I plugged it in and immediately the screen displayed a battery with a thin red line (illustrating no charge). After 25 minutes the device sprang to life and indicated a 10% charge. At 70 minutes the battery indicated 30% charge, and at that rate should be fully charged in under 4 hours. It's fixed!!
Why they didn't say this, I have no idea: HEAT UP THE BACK OF THE PHONE! This helps the adhesive give so much easier, worth the extra 2 minutes to make sure you don't tear anything.
super easy, battery had plenty of glue for what ever reason, I put the screw in 1st then set the battery and was easy to set the new battery. Charge was at 94% strange seeing it next to my Iphone 6 but glad I did it as now I can use it for music and save the battery on the main phone. Thanks for a easy instruction guide.
Strictly speaking re-assembly is NOT the exact reverse of dismantling. In particular do not put the battery in and then try to plug in the connector, Rather, start by plugging in the connector (having straightened the ribbon-wire attaching it to the battery) and only then re=position the battery on its (gluey) base. Also I used a wooden cocktail stick to position the antenna connector correctly (pushing the stick through the hole in the antenna piece and into the threaded base where the screw will eventually go) and then I held it all in place (temporarily) with a tiny blob of Bluetac until I managed to successfully withdraw the cocktail stick and fit the proper screw.
Stuey 25/2/2018
.Heating a towel and wrapping the phone for 3 min did the trick of removal of the battery.
Use a SIM card eject tool or a paperclip to eject the SIM card and its holder.
Remove the SIM card and its holder.
Remove the following two screws:
One 1.2 mm Phillips
One 1.6 mm Phillips
Remove the thin steel dock connector cable cover from the iPhone.
I had trouble with my SIM card at this point. It wouldn't go all the way in - only about 1mm short but enough to keep the phone from being able to read it. It seems that the red screw in this step is the culprit. I loosened it up a bit and the SIM card tray was able to fit flush.
Use an iPod opening tool to gently pry the dock cable connector up off the logic board from both short ends of the connector.
Make sure not to pry too much under the flex cable because you will likely damage the gold / silver shining adhesive tape that is located beneath it.
The guide is missing a comment on this and one would not expect the tape there. Check out the photos of step 10 to get an idea of how the tape looks like.
I assume this to be some kind of head-conductive component.
It won't be much of a problem if you damage parts of it though.
But if you peel off / coil up too much of it, it could get too big and the flex cable could get damaged when it's pressed against it.
Carefully peel the dock ribbon cable off the logic board and the lower speaker enclosure.
This is held down by adhesive, don't try to just yank it off. Peel it slowly. If you damage this cable, you are slightly screwed.
Peel back NOT off. It needs to just pull aside. If it comes off, throw the phone.
Use a plastic opening tool to pry the lower antenna connector up off its socket on the logic board.
NOTE: When replacing the logic board, be sure this antenna remains exposed and doesn't become trapped under the board.
what are you talking about here???
Yeah, would like to know the value of the little blue inductor ... my iPhone 4 doesn't have it any more and I have the worst signal.
I wasn't sure how to carefully detach the antennae. Can anyone offer some insight on how to reattach the antennae? Is it supposed to be soldered to the board? Or is it a pin attachment?
see that tiny little blue thing just to the left of the antenna connector but before the screw? make sure you DON'T knock that out of place otherwise your iphone becomes a heavy ipod touch (yes. this idiot made that mistake while struggling to get the antenna connector back in - which for the record just clips back in). this would have been a handy tip for me while i was reading the instructions, which apart from that little trinket of information, were very easy to follow.
-dan
Remove the 1.9 mm Phillips screw securing the bottom of the logic board to the inner case.
Be careful, I almost damaged this specific screw by using a Phillips #00 screwdriver. It's screwed in tighter than most others. You will need a Phillips #000 or else your #00 has to be a really sharp one.
The cross on top of the screw on my phone is all messed up - not from me stripping it, it just looks like a manufacturing error. The screwdriver won't even fit into the screw, and I can't get it out (I have no idea how they got it in in the first place). Any suggestions?
same here, screw stripped any suggestions?
Couple of ways to get rounded-out-head screws;
1) use a tiny drop of super glue on the top place your screwdriver on the drop/screw, then sprinkle a bit of bicarb-soda on to the wet super glue, it'll harden very rapidly and form a fillet; wait a minute and you should be able to then unscrew the screw.
Be VERY CAREFUL when doing this, because you don't want to have superglue wicking between the screw and the circuit board.
Perhaps practice on some other things first.
I've removed several like this before; frequently I find the culprits for rounded out slots are ham-fisted people trying to do their own repairs in the past.
Get a set of these precision screw extractors. I own a small electronics repair shop and I wouldn't be without them. If you buy them remember that the ends are reversible in case you dull one end. http://www.ifixit.com/Tools/Precision-Sc...
Remove the following five screws securing the Wi-Fi antenna to the logic board:
One 2.3 mm Phillips
Two 1.6 mm Phillips
One 1.4 mm Phillips
One 4.8 mm Phillips
Be careful about the very small spring contact that is under the shield and around the 4.8 mm screw - it can spring out when the shield is removed. It must be reinserted prior to installing the shield, with the thick part up and the spring in contact with the gold pad to the right of the screw hole in the case.
INCREDIBLE! Steve this probably happens to people all the time. The "very small spring contact that is under the shield and around the 4.8 mm screw" I will elaborate on. It's not so much around the 4.8mm screw as it actually part of the assembly where the 4.8 mm screw is tightened. I added an arrow to this picture to visually illustrate:
http://imageshack.us/photo/my-images/9/i...
I had no wifi at all until this was present. I had overlooked the piece and spent hours trying to figure out where it went. BIG THANK YOU to Steve for his comment. After fixing, my wifi was perfect.
Jimmy -
Thanks for your notice! It really helps me.
There is a washer under the plate that is held together by the 1.4mm Philips. This might come loose. Be careful not to lose it.
Confirming this. It's not in the description and it came out when I disconnected the screw. At first I was unsure where it came from, but when I reassembled the phone, the yellow screw didn't make contact, so I realized the washer had to go under the contact plate.
marcx77 -
If a nut under the YELLOW screw is rotating, hold the nut with tweezers.
On my phone the "washer" that the 1.4mm screw goes into I think is actually the mounting post that had come detached. I realize afterwards there was therefore no point removing this screw, but I did remove (and put it back afterwards) by holding onto the loose post/washer with tweezers to prevent it turning.
Print this image out (step 13) - trust me, you'll need it later!
The "washer" that a few of the commenters have mentioned isn't a washer nor a broken post. It is a circular nut that helps the WiFi antenna get a good connection to the logic board. It is part of a sandwich: 1.4mm screw head WiFi antenna logic board ++ circular nut. I held it in place with tweezers and then screwed the 1.4mm screw in. Don't lose this nut!
When I came to reassemble at this step, I noticed the 1.4mm screw no longer had anything to screw to. The nut or washer or whatever it is that you mention has gone. My screen does not work any more. Is this connected and/or is there anything I can do to peplace what is lost?
This screw is supposed to tie into a very small nut that sits under a small u-shaped tab in the EMI shield that is fixed to the PCB. Maybe that nut has moved or got lost. I recommend you to lift that small tab to find it because if loose it could create a short-circuit.
But that screw/nut is absolutely not essential to the LCD. It should work without it.
I used an elastic band pulled taught over the blade of a flat headed screwdriver to hold the nut (beneath the yellow screw) in place. Alternatively I was thinking of carving the eraser on the end of a pencil into a wedge shape to do the same job when tightening the screw on reassembly. Just needs something to grip it in place to stop it spinning.
A note about screw management: ALWAYS remove screws from left to right if you are just putting them in order of removal on a magnetic trey, it helps with re-assembly. If you can, I recommend getting a magnetic white board and writing the size of the screws on it and categorizing by that, it makes it way easier and you won't ever have to worry about putting the wrong size screw in anywhere ever again.
the nut of the yellow screw falls be careful ...to re install it again
Use an iPod opening tool to slightly lift the top edge of the Wi-Fi antenna away from the logic board.
Use the tip of a spudger to pull the Wi-Fi retaining clips away from the inner frame.
Remove the Wi-Fi antenna from the iPhone. Make sure you don't lose the metal clips on the top of the cover where the 4.8mm screw attaches or the 4.8mm screw. That's the primary reason for abnormal Wi-Fi performance after the reassembly.
watch for the connector cover here - it tends to be quite "springy" and may fly towards you when you attempt to release the clips
So as I'm prying the plate off a tiny little nut falls out. I've repaired 4 iPhone 4s now and this is the first time this has happened. Anyone know where exactly it goes? I'd upload a pic, but this forum doesn't support images I see. I'm pretty sure it goes to the long bolt at top center, but where in the stack it goes I'm not certain.
It's probably the nut for the yellow screw of step 13. It sometimes comes off the motherboard, with no adverse effects. Just put it back, under the small u-shaped metal shielding
Yes, that belongs to the yellow screw and is (badly) glued to the motherboard. You'll need very thin pliers to place and fix the nut while reassembling.
mcbohdo -
Use an iPod opening tool to carefully lift the rear camera connector up off its socket on the logic board.
Remove the rear camera.
the rear camera has an extra long tab which runs under the digitizer cable - be careful not to bend this while removing the camera.
Just to clarify, the little tab on the side of the camera does not go under the motherboard, it goes under the cables. This misunderstanding is common for those new to mobile repair. Always make sure you take notes on the small things like this!
Remove the small circular white sticker (warranty sticker and water indicator) covering the screw near the battery pull tab.
Remove the 2.4 mm Phillips screw that was hidden underneath the sticker.
There was no screw underneath the warranty sticker or even a place for a screw. Disappointed.
I removed by accident the other white sticker on the logic board. What happens now? Will the phone work?
It won't hurt anything.
Joshua -
Danger! Since the last screw I took out before is the 4.8 mm (step 13) it can happen that one messes up the order and uses this one instead of the 2.4 mm! This will break the new Display again. I'd add a distinct warnig here to use the right (short) one.
Now I'll a order a new display...
I agree with Ed Williams: no screw under the sticker on my phone.
Use the edge of a plastic opening tool to gently pry the following connectors up and out of their sockets on the logic board:
Digitizer cable (pry from bottom)
LCD cable (pry from bottom)
Headphone jack/volume button cable (pry from top)
Top Microphone/sleep button cable (pry from top)
Front camera cable (pry from top)
Windex didn't work well for me for degreasing the connections. It made the connections worse in fact. Now my digitizer AND my screen don't work.
It seems that you misunderstood the notes throughout the guide. You should only clean metal to metal contact points, such as the contact area between the EMI fingers and the metal case on the speaker enclosure. Applying Windex in connectors or sockets of any type will almost certainly destroy components in your phone.
When re-plugging the yellow connector (the leftmost of the 3 connectors that you disconnected from the top) put the cables behind and not before the metal part with a hole where the EMI Shield 2 clips in. Otherwise you will not be able do step 13.
Be carefull of a very small component soldered near the yellow connector. It can pop off and make your front camera irresponsive.
When reassembling, the various connectors have a leading plastic lip that allows you to align and then slowly snap in place. i pushed on the pads on top of the connectors with the flat tool provided in the kit. Also, the first time, i did not press the LCD cable very well, so the phone was working, but no display showing. once i snapped this in place the second time, it worked like a charm.
After reassembly, when I changed to the front camera, the display got stuck in shutter mode. The website bellow suggests I lost a microscopic jumper that enables the front camera. I am guessing this happened when I disconnected the 3 connectors. The dang jumper is so small I never even noticed that I lost it. Oh well at least the rear camera still works... After replacing screen camera app now stuck on shutter?
I ran into a not workin front camera after a screen replacement on Iphone4. I found out that I had broken the tiny jumper on the main board when I pried off the headphone plug. That jumper is next to the right upper corner of the headphone/volume button plug (yellow marked in step 17 of relacement guide), you can see it in the picture as two silvery dots. If your prying tool sits on that jumper when levelling the plug off, it is history. I took a ampoule of conducting silver liquid, but instead of shaking it I took some of the sediment out with a thin wire and aplied a tiny blob over the two remaining soldering pads left. And alas, it worked ! Front camera is ok again. Thanks to those who found out about that jumper.
On reassembly, be really careful when reattaching the digitizer cable - the cable breaks very easily, rendering your nice new display useless. In my case, I must not have threaded the cable through properly, so it was just a bit too short to reach the connector. I gave it a gentle tug... and snap!
I was much more careful the second time through :(
did you have to buy a whole new display?
same thing just happened to me:((((
mstutz12 -
What is the correct length of flex (ribbon) cable for the Digitizer cable and the LCD cable? I've threaded the cables correctly through the mid frame, however, I keep encountering the same issue. Once I've tried seating the cables into the sockets, the Digitizer cable is too short by approximately 5mm. I've tried several different makes of the front panel display (front screen replacement) but have encountered the same problem with each and the supplier, stating each have been 'defective units'. It just feels a stretch to believe I've been unlucky in purchasing 4 that have all been defective. I can't check these against the original (Apple) screen, as it was too damaged and the removal process of these iPhone 4 screens is a nightmare. Any help is appreciated
Feeding those ribbon cables through the frame is one of the trickier parts of this repair. Check Step 30 of the Display Assembly Replacement Guide for detailed instructions. If you check the comments, you'll find a lot of others have struggled with this—but it can be done! :)
My setup was nothing like this. The headphone jack, top microphone, and front camera connections were not in these locations. Rather, they were on the logic board below the main camera connection. Furthermore, the logic board was held in place by a Phillips head screw that was hidden under a small black piece of tape. This screw also held the small gold connector tab. Additionally, the bottom of the logic board was held in place by a Phillips head screw.
Sounds to me like you have an iPhone 4S. This guide is for the iPhone 4. ;)
Remove the 4.8 mm standoff screw near the headphone jack.
Without this part, the motherboard could damage the ribbon cables around it.
The smallest screw below the Digitizer connector is held by a tiny nut which is fixed below the EMI shield. Beware because this thing can get loose easily.
Is this it? http://i.imgur.com/AQlJS8g.jpg
crimney -
I believe that's the one he's referring to...
Joshua -
The screw anchor/stud came loose on me as well... How did you repair it? If you left it broke did it effect anything?
iyacyas -
Image of rectangular rubber piece
Thank you Rajan for this picture. The rubber piece fell out and i was frantically trying to find its spot.
Yes! Thanks for this pic! I found this little piece in the body of the phone after I removed the logic board and was stumped! Real lifesaver!
Joshua -
I have found that the easiest way to remove these standoffs is to loosen them with a 2.0 or 2.3 mm standard (flat) blade driver bit. Then, once it is loose, you can either loosen it the rest of the way, or for better control, insert your pentalobe driver into the center of it and loosen it the rest of the way. If your pentalobe driver won't turn it, then it is not loose enough, or the end of one of the small screws has broken off in it (actually fairly common).
Best of luck to you! Just ask if you need more info!
Joshua -
there are several versions of what appears to be the iphone 4S. It has more screws and a hidden 4.8mm flathead at the top close to where the exposed one was in this step. I rendered my iphone useless not knowing this. If you have this version, stop, put everything back and bring it to a professional, or you will find about 6 or 8 extra pieces that are not covered in these instructions and a broken phone as well.
Wesley, this is the guide for the iPhone 4, not the 4S. The two are distinctly different.
There's no multiple-variants of either model to best of my knowledge (having repaired hundreds of both the 4 and 4S)
Didn’t see the comments about the rubber strip until too late - severed the digitizer ribbon cable on the edge of the board! Screen worked fine, but no touch control - had to buy a new screen and do it all again…! :(
Carefully remove the logic board from the iPhone, minding any cables that may get caught.
Missing rubber guard can causing touchscreen sensitivity & accuracy problem.
Do not forget the rubber piece. When replacing my home button, I noticed this rubber piece fall out of the phone, and couldn't figure out where it went. I left it out, and my touchscreen had all sorts of problem. I thought I had damaged the digitizer ribbon. I even bought a new screen and had similar problems after putting that in. I finally put a makeshift piece of rubber that I cut up into the spot where this rubber piece had gone, and currently haven't had problems for over a week. This rubber piece must suppress interference problems of some kind.
Great point! I had the logic board put back in and then found this little thing hanging out. I found a "tip" on a different site that showed it going between the rear-facing camera and the logic board! Thanks!
Joshua -
Can we get a better photo of where rubber piece goes? Mine fell off, and I have no idea where to put it back on to.
It goes on the edge of the logic board where the Digitizer and LCD Panel ribbon cables bend over the Logic Board before they plug into it. The rubber piece protects the ribbon cables from chafing like a bumper and from interferance.
fasthans -
You can see it on the upper left of the Logic Board, just to the right of the camera in the photo for Step 18. It is easier to see if you click on the view huge link to blow up the photo.
fasthans -
Ear piece metal connectors: You can see them on step 22. If those are not bent up enough (laying flat) you won't have contact with the logic board... and no more audio from the ear piece. This is what happened to me. I had to unmount it again to bend them and hop the ear piece worked again!
This was a very tricky part. Just make sure that you don't put pressure on the login board to get it into place, take your time and ease it in. There will be a bit of spring in it when you push down which is a combination of the folded LCD and Digitizer Ribbon Cables and the two copper contacts underneath.
This was absolutely the hardest part - had to do it over many times. The digitizer ribbon cable kept insisting on folding up under the logic board. Tip: do not let the cable fold up, even it that's how it naturally wants to go, it will be too short.
hi, the small gold prong (step 19) in my phone is fragile what should i do? what function from that small gold prong? thank you
288 outras pessoas concluíram este guia.
15 comentários
I did a thorough surgery of mine today. Ppl couldn't hear me at all, so I had to get to the logic board.it was not challenging at all. One has to be careful with the antenna area so as not to apply to much force thereby damaging it. However,if u couldn't clip it back,just use a paper tape to hold it down b4 placing the battery plate on it. I recoupled the phone and everything work excellently. Ppl can hear me clearly now
Will a iphone 4 motherboard bought from china on ebay work on a phone in usa. And will I'll be able to use it with any company.
Does the logic board come with iOS 6?
i never owned i phone in my life but i purchesed some broken ones the other day 2 were i cloud locked 1 disabled other 3 not turning on the disabled one i manage to bypass and get it restored but still stuck with a broken front screen so i just swapped the board over to a i cloud locked phone with good screen and bingo i now have a a1 cond i phone fully working brilliant site and info u have many thnks
ps im the most impatient person in the world when it comes to tech things but so easy to follow here made it so much easier
I did all this and now it won't charge...help?
My guess, the dock connector didn't go in right / got damaged.
Put logic board from broken iPhone 4 into new iPhone 4 now it keeps rebooting every minute or so. What could be causing this ?
After doing a screen replacement my WiFi range went down to about 12 feet, and Bluetooth connectivity was inexistant. Taking out the logic board I had lost the tiny rubber protection at the top end, and replaced it with a piece of rubber which was too thick. As a result the tiny golden hook did not quite touch the steel frame, which is acting as part of the WiFi, BT and GPS antenna. Having removed my improvised protection strip and replaced it with a thin layer of glue, bent the gold connector out a bit, and re-installed the logicboard 0.5mm further up, I've got back WiFi connection to a mast 500 m away. So it's not just important to screw in tightly the long top screw of the black WiFi Antenna/EMI shield, make sure the little gold hook of the logicboard is in good contact with the steel frame too. I cleaned the steel frame with Isopropyl alcohol too.
Wow! Thanks dude. You are the best.Your tutorial is very clear.and in very easy to understand English. You explained very well to even make an inexperienced person be able to replace the logic board. I had never done it before. I read and followed your tutorial taking note of all the warnings and cautions. I was able to replace my logic board which was network locked without any issues. I now enjoy my “new” unlocked iphone 4. It really helped me save a lot of money.
You are really a genius!!!!!!!!!!!
What storage is with your logic board?
using something like the 18-compartment tray will GREATLY help with this one; there are over a dozen groups of parts. For re-assembly having a digital calipers to measure the 2.4 vs the 2.6mm screws also helps greatly.
awr - Responder
My method for hardware management during delicate phone surgery is to take and print out on 8.5"x11' paper, one or more pictures of the open phone in various stages of disassembly, and then tape the screws to the appropriate spots on the pictures. Also write numbers on the pictures next the screws to indicate the order in which you removed them.
lens42 -
I use a plastic egg tray, I drop all the screws and small parts (like the camera) for each step into the same egg indentation. You can see that the screws are different lengths, so I don't put one screw into it's own spot. I used 5 egg indentations to replace my screen.
robin -
I did a successful surgery on my iPhone, be warned this is not for the faint of heart!
I've done iPod screen replacements, battery replacements, this is by far much more difficult and intricate.
Great write up! Thanks a million.
Jaysen Strange - Responder
I've changed some iPod screens as well and that has been the least pleasant experience so far. Glue and the main connector that has to be unwrapped and connected from the rear where you have no feel or control where it belongs.
iPhone repair is complex, but doable and has very few "traps".
mcbohdo -
Couldn't even get both screws out of the bottom of the case. One was easy and other refuses to budge. Screws so small I can't see if it is turning or screw driver is properly seated. Sad I too have done screen replacements on other phones. Don't know any secrets to get the screw out
ckracht - Responder
I also have a problem with seeing what is happening with some of those tiny little screws and parts. For other projects that I do, I use an Opti-Visor. It slips over your head and provides 10x magnification. ( You can find them on Amazon).
Yeah, it adds cost to the project and you would have to wait for delivery, but it sure makes a world of difference in seeing what you are working with / on.
jhow -
On an early iPhone 4 I found that the #000 Phillips bit included in the 54 Bit Driver Kit didn't actually fit the screws. However the JIS #000 also in the kit did fit quite well. This is due to the JIS bits "thinner" design to prevent camming out of the slot. Otherwise everything went well. Looking forward to replacing the battery in my other phone that has the pentalobe screws. Glad I got the 54 Bit kit!
etler - Responder
Use a vacuum duster and a sharp tool to pry out the dust, this can increase the volume insanely!
Dpairs - Responder
What does the park that is gold and next to the 4.8mm screw for the antenna? Looks like I am missing that part and almost positive that is why I can't pick up or connect to any wifi signals. I have the screw and the antenna from another phone that is working and tried it on the broken phone and still doesn't work. Only thing different is that gold metal piece to the left of that 4.8 mm screw. Can I buy that part? how do I attach it?
Jay Pennington - Responder
great instructions did it the first time
Mr J - Responder
For organisation of the parts and for a much easier process of rebuilding i use a big magnetic flat surface with a grid drawn on it. Then I use a dry erase marker to make any notes I need and to number the parts in order as i disassemble . Believe me it saves a lot of time and hassle especially if you drop one of those tiny screws good luck finding it but when your working over the magnet and drop a screw its going to be right where it fell. At first I tried the piece of paper to keep organised but all it takes is one small slip and you move the paper too quick and your left with a jumbled bunch of screws and parts and a painstaking task of putting it all back correctly, aka a big waist of time and effort.
case-yg - Responder
I found it very useful to use a magnet sheet when doing these repairs. I use electrical tape or a sharpie to make a grid, and place each micro screw in a separate box on the grid.
I work directly over the magnet sheet, so that if something drops I have a better chance at not losing it.
If you do lose a screw, go over the work area with a fridge magnet. It will pick it up if it hasn’t popped too far away.
Megan Telliano - Responder
Awesome, very helpful information
Jenna Betty - Responder
