Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
O que você precisa
Power off your iPhone before beginning disassembly.
Your iPhone 4 rear cover may have either two #000 Phillips screws or Apple's 5-Point "Pentalobe" screws (second image). Check which screws you have, and ensure you also have the correct screwdriver in order to remove them.
Remove the two 3.6 mm Pentalobe or Phillips #000 screws next to the dock connector.
Remove the single 2.5 mm Phillips screw securing the battery connector to the logic board.
Use an iPod opening tool to carefully pry the battery connector up from the ends closest to the top and bottom edges of the iPhone.
Remove the contact clip from the iPhone.
Before reconnecting the battery connector, be sure the pressure contact (shown in red) is properly positioned next to the battery connector.
91 outras pessoas executaram este guia.
