Ir para o conteúdo principal
iPhone 4 / 4S / 5 / 5S / 5c / 6 / 6S - how to flash from DFU mode. Password recovery.
Guia arquivado
Este guia é mantido exclusivamente para fins históricos. Use a versão atualizada do guia para executar o reparo.
Vídeo de Apresentação
  1. iPhone 4 / 4S / 5 / 5S / 5c / 6 / 6S - how to flash from DFU mode. Password recovery., iPhone 4 / 4S / 5 / 5S / 5c / 6 / 6S - how to flash from DFU mode. Password recovery.: passo 1, imagem 1 %32 iPhone 4 / 4S / 5 / 5S / 5c / 6 / 6S - how to flash from DFU mode. Password recovery., iPhone 4 / 4S / 5 / 5S / 5c / 6 / 6S - how to flash from DFU mode. Password recovery.: passo 1, imagem 2 %32 iPhone 4 / 4S / 5 / 5S / 5c / 6 / 6S - how to flash from DFU mode. Password recovery., iPhone 4 / 4S / 5 / 5S / 5c / 6 / 6S - how to flash from DFU mode. Password recovery.: passo 1, imagem 3 %32
    • Open iTunes. The iPhone must be connected to the PC and powered OFF.
    • ATTENTION, ATTENTION: You will lose all your data. Be sure that you have backup.
  2. iPhone 4 / 4S / 5 / 5S / 5c / 6 / 6S - how to flash from DFU mode. Password recovery.: passo 2, imagem 1 %32 iPhone 4 / 4S / 5 / 5S / 5c / 6 / 6S - how to flash from DFU mode. Password recovery.: passo 2, imagem 2 %32 iPhone 4 / 4S / 5 / 5S / 5c / 6 / 6S - how to flash from DFU mode. Password recovery.: passo 2, imagem 3 %32
    • Entering DFU mode.
    • Instruction you can read at the description.
    • iTunes has detected an iPhone in recovery mode.
    So please how to flash it without a Computer?
    I need to flash Manuel....
    kasimubinaron - Responder
  3. iPhone 4 / 4S / 5 / 5S / 5c / 6 / 6S - how to flash from DFU mode. Password recovery.: passo 3, imagem 1 %32 iPhone 4 / 4S / 5 / 5S / 5c / 6 / 6S - how to flash from DFU mode. Password recovery.: passo 3, imagem 2 %32 iPhone 4 / 4S / 5 / 5S / 5c / 6 / 6S - how to flash from DFU mode. Password recovery.: passo 3, imagem 3 %32
    • Select "Restore iPhone" and iTunes will download and install the latest firmware for your phone.
    nice yar kya bt ha
    ikram - Responder
    il faut une application sur la machine ou bien on le branche seulement
    etoundizene.yvantedy - Responder
  4. iPhone 4 / 4S / 5 / 5S / 5c / 6 / 6S - how to flash from DFU mode. Password recovery.: passo 4, imagem 1 %32
    • Your iPhone is factory restored now.
    • Did you do it successfully?
    itune ne detecte meme l'iphone
    pachat nobel - Responder
    j’ai bien commencé mais lors du téléchargement le phone s’est allumé de lui même. pourquoi ???
    corneillehouessou - Responder
    “Password recovery” is where?
    Mike Moran - Responder
    I cannot reach the 4th step ; my iPhone 4s return to recovery mode and can’t restore why ?
    and when I try to flash it or exit the recovery mode from “ 3utools “ it fails and doesn’t work.
    benzmadjid0324 - Responder
    avec cette technique j’aurais encore besoin d’entrer le dernier compte iCloud utilisé sur le téléphone ou bien
    tchapda daniel - Responder
Conclusão
This guide does not need reassembly.
455 outras pessoas executaram este guia.
ZFix
Membro desde: 12/09/13
191.278 Reputação
Autoria de 330 guias
Equipe
Master Techs Membro de Master Techs
Community
Membros da 322
Autoria de 2.528 guias
99 comentários
This is not flashing anything just resetting the iPhone...
Newbye - Responder
You are wrong. This procedure reflash the firmware, but if your phone is already with the latest version, for you this will looks like full reset.
ZFix -
My iphone 4 is locked and i dont know the apple id so by doing this i can unlock it or not please help
mehtashivani44 - Responder
If your phone is carrier locked or iCloud locked - no.
ZFix -
contact me to unlock iphone 4 icloud lock
Himanshu Rattan -
@Himanshu Rattan
how can i contact?
Mailna Patel -
My iphone 5 is locked with icloud and i dont know the apple id and password so by doing this method i can unlock it or not
Sathish - Responder
When i connect my iPhone in pc it doesn't shows in pc.
Comment via:- http://www.Techmash.in
Swatntra - Responder
how if there's icloud account logged ? it will be icloud locked?
harlievhincruz - Responder
Officially the iCloud lock can be removed only fro the owner.
ZFix -
I got problem with my iphone 4s icloud I'd I don't know how to remove plzz help me
mudassar ghumman - Responder
I don't know how to solve your problem when your iPhone get into DFU mode, but I know how to recover iTunes backup password if you forgot iTunes backup password, I personally suggest you try iSeePassword iTunes backup password recovery.
Duncan7722 - Responder
I can hear voice of my iphone 4s on call and ring tone properly but when it comes to play music or listening whatsapp voice message i cannot hear voice without headfone.... Can somebody help
Arslan - Responder
same problem i am facing can anyone help us
Raju Ahmod -
I have some problem of my iphone 4 (wifi disable)
how to resolve...
can anybody help me???
Rehan Ansari - Responder
My phone is stuck in recovery mode and it will not come out it. Could you help and tell me what to do to try and to get it out recovery mode. Thanks
jackmills6 - Responder
no way i will be getting this
KENIYAH -
I'm doing the update and restore on my iPhone5s but when it gets to restoring firmware it stops and says an error occur. I've tried over and over again still the same. Now when I turn the phone on all it shows is the iTunes logo and usb sign under it. Please what do I do?
Biggie Wire - Responder
sicrt cold u can use to open ur phone
pogasti gh -
my iphone 5s was downlaoding new update and crashed half way now conctant error 50 and stuck on conect to iitunes
paul - Responder
Hello,
I bought a second hand iphone6 plus from a friend. And I went to go use it and I can't because it is still conceded to the original owners apple Id account. And I have NOOO WAAYYYY nor do I know the original owner.
What do I do?
Please help
Thank you
Trina - Responder
go back to your thieving friend!
Albert Einstein -
Hallo, i bought a second hand iPhone 6s 64gb in italy and it works perfectly but not for thelephone function becouse of the imei. If you have a iPhone like mine that works evrywhere but not in your nation you can exchange with mine
Francesco - Responder
Itunes say "off find my iphone" but my iphone is in disable mode cause i forgot password
Shahzaib Kiyani - Responder
My Iphone 6s+ is disable nd didnt get backup nd didnt known apple id nd password say me in detail plz sir say me
ya email / whats app me
patelharshp2015@gmail.com
+918866181732
harsh patel - Responder
My Dad Bought An Iphone 5s, And Now He Forgets The Password And Everything That Linked With The APPLE ID. How to Remove That Account outta my Iphone?
sekar11398 - Responder
Please my iPhone 6 is showing disabled but can't be detected on the pc when plugged.can it be re flashed even if t warrant me losing all my data's?
Andrew - Responder
Iif you flash an iphone 4s trying to unlock it and after couple of hours the iphone refuses to turn on again what can be done to it,this iphone is a gift and it has been locked down to only emergency calls.
metrobugs01.50@yahoo.com - Responder
i am at step 4 and i am receiving this "Your iphone could not be activated because the activation server cannot be reached.
Try connecting your iphone to iTunes to activate it, or try again in a couple of minutes. If this problem persists, contact Apple Support at apple.com/support.
Here i am please help
naxmotmols - Responder
what is activation server?
forgot the password of the apple id,so by flashing it can it help me to create a new one?
nomvuzo - Responder
no you cant if you turned on Find My iPhone. if you follow this guide while turning Find My iPhone on, when you make activation then it will require you type the apple id existed before. now this guide cant remove password.
ycwei982 -
Mybe you can read the Tunesbro tutorial , i have looked it , in this tutorial , you can get more about how to repair all kinds of iPhone problem, such as recover data ,erase data ,and fix the iPhone from recovery mode
Kmater - Responder
Thanks for this guide. Nice job (y)
Ivette Carlier - Responder
my iphone 5s stack at apple logo after i did restore,how to solve this
basra321 - Responder
where firmware any i phone link....plz....
Hameem Ahmeed - Responder
Try this site, if you haven't found one yet!
https://ipsw.me
helliant1 -
hello, my iphnone 5s fell in water and now its try to turn on but keep rebooting. i have tried to put it in DFU mode but its not responding. what can i do please help me
ngekuh boniface - Responder
Have you ever tried any guide to recover your phone from getting water? If not, go for it. I suggest you using recover mode at first, as it has response on the screen. Turn on your phone, and when it shows Apple logo, release power button then long press the home button. If it works it will show "Connect to iTunse".
ycwei982 -
my iphone is not icloud locked.. is this going to remove my password ??
siyolise qwemeshe - Responder
frimwar iphone : http://bluenik.com/1Esr
l’iPhone et l’iPod Touch, l’iPad, l’iPad mini, l’Apple TV ainsi que toutes les version d’iTunes :http://bluenik.com/1Esz
lovemeloveme803 - Responder
not working to me... i have iphone 4 32gb... http://indoxxi.info nonton film movie online
erna nitami - Responder
When restoring my Iphone 4s with iTunes it gets stuck at waiting for phone.
What do I need to do?
Jaco - Responder
My i phone 5 when i switch on automatic on nd off just lyk
what is the prblm just showing white screen nd apple symble thats it
Mirza - Responder
Can u explain me what i do now
Mirza - Responder
My iphone4 is locked with Apple ID .with this process can I flash the iPhone please help
Osayuki Obaseki - Responder
Hello,
I'm sorry but if your device is locked with an Apple ID, this guide will not help you. Only you can do is to login with the Apple-ID which is linked to your iPhone.
Zaim -
My iPhone 5c is full/ZERO memory storage. I compute all the data/apps that I've downloaded and 1GB+ free space must be remained. I do delete some apps, vedios, pics and etc. but it still full memory storage.
This DFU mode can fixed it?
Thank you.
GoyPAngZ - Responder
Hy,
if you boot your iPhone in DFU mode and proceed a restore, all data will be removed and it will look like a new iPhone.
Zaim -
my iphone is locked and i cant get my apple id
Everton IFY - Responder
when its extracts the file in itunes it restarts again and again
Vinayak Devadiya - Responder
my iphone 6, which i have used for a year plus has been disabled, i forgot my pass-code just after changing, i have tried restoring buts there comes an error...'disc full, delete and empty the recycle bin . retry again"
how can i do it yet its already locked? help please.
george - Responder
You have to put it in the DFU Mode and not in to the restore mode
Zaim -
My iPhone in locked with icloud but I forget apple id and password and I also loss my all apple document . So how can start my iPhone plz advised me sir
Tony - Responder
When you turn you iPhone on, there is a hidden email with big black dots in it, you have to reset your password for this email, otherwise you can throm you iPhone away
Zaim -
Do i need to download any app on my pc?
derasnotion - Responder
Yes, you have to download iTunes. You can download it from itunes.com
Zaim -
i dont remember my icloud account ,so my problem is i stuck in icloud account ,i reset my phone then i cant log in .they said incorrect password
tmae pat - Responder
You can go here: https://iforgot.apple.com/password/verif... and reset you password
Zaim -
Will This unlock me from straight talk?
The White Kyrie - Responder
my iphone 5 has been labeled “connect to itunes” but when i connect, it doesn’t show on my pc….. can some one help please
Michael Love - Responder
I really hate flashing apple devices….
Deekshith Mclaran - Responder
give me sicrit cold to poen i phone
pogasti gh - Responder
BTSjxciivbobl
syed - Responder
yar thori urdu v type kiya karo kisi aur ko be samj a jay
ch.tahir84 - Responder
je veut enlever icloud pour mon iphone 5s quoi faire svp
hamnane - Responder
mon iphone 4 s fixe sur image appel et non demarre pas
laifaoui - Responder
My iphone 5s is icloud locked. Bought it from second hand. Please help
John Simiyu - Responder
So you can't reset the iCloud locked iPhone 6s?
Da Niel - Responder
Photos taken with my iPhone didn't display on Android phone but they display on other Iphone. Photos are in .JPEG format. I am running virus?
Amidou - Responder
I have Iphone 4 and is Icloud lockes. How can I resolve this? Mail me at daphethy@outlook.com
Lephethesang - Responder
my father passed on three months ago and on his iphone is where the will is and all of us do not know the apple id and password, whoever can help unlock, a big reward awaits. BEN , benokello000@gmail.com
Ben - Responder
Pls how can i unlock iphone 6 that has icloud lock
balo lanre - Responder
This is very nice guide how to unlocked your iPhone. But I use one of this to unlock my iPhone 8 on other SIM card. I thing that this tool can’t unlock any iCloud Locked iPhone.
Adams Bell - Responder
hi My iPhone 6 was 32 Gb and after the guy repaired than its now 16 Gb … loll and the guy is asking me to flash restore the phone I did that but its still the same….
what can be the reasons???
I am going to him again today
gauravllll - Responder
My sister bought iPhone 5 locked by iCloud and password now she can't use the iPhone and a person who sold the iPhone disappeared. Help please.
Moises Nhavene - Responder
pls pls help me remove icloud from my iphone 5
petersammy125 - Responder
this only reset the iPhone!! the problem is not solved as it still locked qnd i m enqble to use q new SIM Card. Just lost everything…..
amal.bena - Responder
Check Here i am also have some solution to flash Iphones- How to Flash iPhones without iTunes
GD18 - Responder
Can I recover my lost password without loosing data? Technikola
Technikola All Tech News - Responder
Please my dad forgot his apple ID ND he already flashed the iPhone and he can't remember his email too..please what do I do??
AKINDOLIE DOLAPO - Responder
Bagaimana cara,y buka iphone 5s
Muhammad Akbar - Responder
bonjour comment faire alors pour importer un fichier ios avant de lancer la restoration
kengele - Responder
I got error massage after all procedure
nongmaithem arunjit - Responder
bsr moi jai fait toute la procédure normalement jusqu’à l’étape de l’extraction du logiciel, mon forfait est fini et depuis ca n’avance plus malgré que j’ai renouvelé le forfait. Que faire svp?
krys - Responder
İphone 7 plus we have it droped. I try do restore it. İt gives me the error 1. İtis not good error ı know that. What we are going to do first .?
firat020 - Responder
What is the error that you are seeing on your iPhone/iTunes? That would better help us to determine what your next steps are to be taken!
helliant1 -
have an iphone 4s whic h i collected kindly unlock for me
Benson Muteka - Responder
hi Himanshu, I have a iPhone 5S locked icloud, do you know how to unlock it ?   my email : georges001@cegetel.net
Georges - Responder
it doesn’t work with icloud removal
frimpongnicholas43 - Responder
where do i get firmware of iphone 6 plus
slt j’ai un iPhone 6 qui redémarre en boucle sans cesse au niveau de la pomme comment y faire? merci.
ARMEL Onguene - Responder
I need help on resetting my iphone 4
lil preshy - Responder
My iPhone 5s is on ICloud pls I can I remove it
olaoyedaniel ibukun - Responder
How can I remove my iPhone 5s from iCloud. I no my username but I can’t remember my password
How can I contact? My iphone 4 is locked and i don’t know the apple id
elcanoseba - Responder
Salut!! Mais es-ce-que céla permettra de supprimer le compte iCloud sur l’iphone?
Abdallah Sabibou - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 9
Últimos 7 dias: 76
Últimos 30 dias: 301
Duração total: 502,737
