Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Peças e ferramentas
Introdução
Entering DFU Mode (Official Instructions)
1. Plug your device into your computer.
2. Turn off the device.
3. Hold the Power button for 3 seconds.
4. Hold the Home button without releasing the Power button for 10 seconds.
5. Release the Power Button but keep holding the Home button.
6. Keep holding the Home button until you are alerted by iTunes saying that it has detected a device in Recovery Mode
Make sure the device screen is blank and no logos are present. Same operation you can use for all other models of iPhone.
Vídeo de Apresentação
  1. Open iTunes. The iPhone must be connected to the PC and powered OFF. ATTENTION, ATTENTION: You will lose all your data. Be sure that you have backup. ATTENTION, ATTENTION: You will lose all your data. Be sure that you have backup.
    • Open iTunes. The iPhone must be connected to the PC and powered OFF.
    • ATTENTION, ATTENTION: You will lose all your data. Be sure that you have backup.
  2. Entering DFU mode. Instruction you can read at the description. iTunes has detected an iPhone in recovery mode.
    • Entering DFU mode.
    • Instruction you can read at the description.
    • iTunes has detected an iPhone in recovery mode.
  3. Telas LCD de reposição iPhone (com ferramentas)
    A opção econômica, coberta por nossa garantia vitalícia.
    Confira os kits
    Reduza os custos de reparo, não a qualidade.
    Confira os kits
  4. Select "Restore iPhone" and iTunes will download and install the latest firmware for your phone. Select "Restore iPhone" and iTunes will download and install the latest firmware for your phone. Select "Restore iPhone" and iTunes will download and install the latest firmware for your phone.
    • Select "Restore iPhone" and iTunes will download and install the latest firmware for your phone.
  5. Your iPhone is factory restored now.
    • Your iPhone is factory restored now.
    • Did you do it successfully?
Conclusão
This guide does not need reassembly.
455 outras pessoas concluíram este guia.
ZFix
Membro desde: 09-12-2013
169.559 Reputação
306 Guias de autoria
equipe
Master Techs Membro de Master Techs
Community
293 Membros
840 Guias de autoria
This is not flashing anything just resetting the iPhone...
Newbye - Responder
You are wrong. This procedure reflash the firmware, but if your phone is already with the latest version, for you this will looks like full reset.
ZFix -
My iphone 4 is locked and i dont know the apple id so by doing this i can unlock it or not please help
mehtashivani44 - Responder
If your phone is carrier locked or iCloud locked - no.
ZFix -
contact me to unlock iphone 4 icloud lock
Himanshu Rattan -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 18
Últimos 7 dias: 151
Últimos 30 dias: 2,938
Duração total: 481,280
