Introdução
The vibrating part of the iPhone.
O que você precisa
If your display glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping the glass.
Lay overlapping strips of clear packing tape over the iPhone's display until the whole face is covered.
Remove the two Phillips #00 screws from the dock-connector end of the iPhone.
Remove the following 8 screws:
Five 2.3 mm Phillips #00 screws with partial threads securing the logic board to the rear panel.
Two 2.3 mm Phillips #00 screws with full threads securing the logic board and camera.
One 2.9 mm Phillips #00 screw from beneath the "Do not remove" sticker.
79 outras pessoas executaram este guia.
2Comentários do guia
Es wäre sehr gut wenn Sie die Anleitungen auch in deutsch angeben könnten.
M.Marchewicz
Warum nur in englisch ???
