Ir para o conteúdo principal
iPhone 3GS Proximity Sensor Ribbon Replacement
O que você precisa
  1. iPhone 3GS Proximity Sensor Ribbon Replacement, Proximity Sensor Ribbon: passo 1, imagem 1 %32
    • Remove the screw that holds this bracket in and put it in a safe place.
  2. iPhone 3GS Proximity Sensor Ribbon Replacement: passo 2, imagem 1 %32
    • Use an automotive pick tool to lift the bracket up on the side of where the speaker lies. Slight upward pressure, do not force or pry.
  3. iPhone 3GS Proximity Sensor Ribbon Replacement: passo 3, imagem 1 %32
    • Do the same with the other side and on the bottom of the bracket. This is held in with tension on fingers that clip into the screen midframe.
  4. iPhone 3GS Proximity Sensor Ribbon Replacement: passo 4, imagem 1 %32
    • Once the bracket is loose, you can pull it up carefully maneuvering it up and around the LCD and digitizer connectors.
  5. iPhone 3GS Proximity Sensor Ribbon Replacement: passo 5, imagem 1 %32
    • Peel the old ribbon from the bracket, note the orientation.
  6. iPhone 3GS Proximity Sensor Ribbon Replacement: passo 6, imagem 1 %32
    • Peel off the adhesive backing protectors from the new ribbon, and line up the holes in the ribbon with the ones on the bracket as so.
  7. iPhone 3GS Proximity Sensor Ribbon Replacement: passo 7, imagem 1 %32
    • Use a small screwdriver's shaft to conform the new ribbon to the bracket's contour. Light pressure is only needed.
    • At the top of the ribbon, note that there are two small holes. Align them with the two holes in the metal piece for a perfect fit.
  8. iPhone 3GS Proximity Sensor Ribbon Replacement: passo 8, imagem 1 %32
    • Lift the digitizer and LCD connectors and snap in the bracket/ribbon combo to finish it off.
Conclusão
60 outras pessoas executaram este guia.
hectordtruong
Membro desde: 05/16/10
7.404 Reputação
Autoria de 1 guia
8Comentários do guia
Thanks for this. I ruined the proximity sensor cable when I was repairing another part on my wife's phone (!)
Your guide helped me get her phone back in perfect working order.
Thanks!
Tyler Faile - Responder Compartilhar
My pleasure!
hectordtruong - Compartilhar
I used this guide to replace my speaker + proximity cable since I damaged the cable when I replaced the iPhone battery. Worked like a charm and all is good again, thanks for this guide it helped me out big time!
timverbist - Responder Compartilhar
No problem, thanks for the comment!
I did not have a automotive pick, but I found that a straight pin from a sewing kit made it pretty easy to pop this module off.
Evan Dozier - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 13
Últimos 30 dias: 53
Ao todo: 92,468
