Introdução
Connects the iPhone to a computer or charger via iPhone cable.
O que você precisa
Vídeo de Apresentação
If your display glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping the glass.
Lay overlapping strips of clear packing tape over the iPhone's display until the whole face is covered.
Remove the two Phillips #00 screws from the dock-connector end of the iPhone.
Remove the metal handle from the suction cup. It's easier and safer to grip the suction cup's base instead of the metal handle.
Use a small suction cup near the Home button to gently pull up the bottom portion of the iPhone's display assembly.
Rams is right on here.
The cable labeled 4 in step 3 may have adhered to the back of your LCD. Mine ripped when I opened the phone. Now the dock connector needs to be replaced as well.
Citação de postnospam:
This is exactly what happened to me!!.. found the dock connector online for $20 (ebay)
Rotate the display assembly up until it is at an angle of approximately 45 degrees.
For me, the ribbon cable 1 became disconnected when lifting the screen to ~45 degrees. Nothing tore at least, it just popped up/out.
Use a spudger to flip up the white plastic tab holding the remaining ribbon cable in place. The white tab will rotate up 90 degrees, releasing the ribbon cable.
Slide the black ribbon cable out of its connector, and remove the display assembly from the iPhone.
I found that the tab I needed to flip up was black not white. There is a white piece of plastic that the ribbon slides under but it's the black piece of plastic it slid into that I needed to lift up. I found it quite tricky re-assembly this part, I thought I needed to slide the ribbon in further when in actual fact it was already in far enough.
Citação de Joe Fleming:
Wow wow wow... wait a minute: DO NOT TRY to flip up the black part (the thingy on the north side of the phone) but the WHITE PART (on the south side)!!! I almost wrecked that connector trying to pry up the black part! It's definitely the white, tiny tab that flips up!
Citação de Sawatzki:
Ok, just to clear this up: It seems that at Joe's iPhone, the colors of the parts were different than on mine and the one in the picture.
To get this crystal-clear: the part that flips up is the one facing AWAY FROM THE CABLE. Imagine the cable being on the NORTH SIDE of the connector, the tab to flip up is ON THE SOUTH SIDE.
Be very careful when removing and reinstalling Ribbon #3. Do not bend it with your fingers or use mechanical means or installation or you will damage it (I had to replace mine). Ideally, hands off. This ribbon controls the light sesnor and earpiece. When you reinstall, gently slide it in by holding the screen assembly only. It will go in about 65% of the way, which is as far as it is intended to go.
ARRRGH. OK, wish I had read the notes before trying this. I tried to move the black part as described & broke the connector. Now I'm SOL. I actually fixed the antenna connector which is the reason I opened it in the first place but now it's useless as a phone because I can't hear audio from calls through the speaker anymore. Can't someone please add a note like this to the original guide instead of hoping people will look at the notes??!!! If it had been there, I'd be happily using a repaired phone right now instead of looking at a broken one.
Carefully peel up the small sticker labeled "Do not remove."
the little sticker "do not remove" is very fast, very broken ....ups ;)
That sticker sticks like !@#$. Could only scratch it gently away from the screw it covers.
Remove the following 8 screws:
Five 2.3 mm Phillips #00 screws with partial threads securing the logic board to the rear panel.
Two 2.3 mm Phillips #00 screws with full threads securing the logic board and camera.
One 2.9 mm Phillips #00 screw from beneath the "Do not remove" sticker.
Remove the following 3 screws:
Two 1.5 mm Phillips #00 screws, one on either side of the dock connector.
One 2.4 mm Phillips #00 screw near the ribbon cable labeled "4."
Take a look at the small spacer just below the "4" connector. Some dock connectors out there do not have the small spacer. I experienced a couple of times that the (4) cable had popped out of the connector after using the phone for some days. The cable is a little stiff. The small spacer helps press down the cable onto the connector so it doesn't jump out.
Lift the dock connector assembly up and out of the iPhone.
I broke my speaker and the mic. Don't you have further steps how to disassemble the dock connector from the speaker and mic? Thank you
Citação de Szabo David:
Hi David, you can buy the part as one, I bought the following... http://cgi.ebay.co.uk/ws/eBayISAPI.dll?V...
Oh great, thank you! Don't you know whether it fits the iphone 3GS? Are these parts same for iphone 3G and 3GS, I cannot find on ebay one for iphone 3gs.
David
David
iPhone 3GS Complete Dock Charge Port Connector Assembly...
I did need to do a reset of my iPhone once installed since my Photos app wasn't launching. Might be unrelated to new hardware, but it's most likely recommended to do an iPhone reset after installing.
The whole walkthrough was pure money. I tore the ribbon cable off the dock connector while seperating the whole assembly but the replacement went in without an issue and this walkthrough was pure MONEY!!!!
THANKS AGAIN!
If the replacement dock connector assembly doesn't have the foam pad over the connector (labeled "4" on the original part), carefully transfer it to the new assembly, lifting as much of the adhesive off with the foam pad as possible.
If the replacement dock connector assembly doesn't have the wire mesh pad on the flex circuit (close to the connector labeled "4"), carefully lift it off with a knife or other thin tool, taking care to keep as much adhesive as possible with the mesh pad. Then transfer it to the same spot on the new part.
172 outras pessoas executaram este guia.
Um comentário
Hm, swapped the docking assembly, but now my phone will only show the apple logo for a few seconds, then goes black. Switched back to my original dock connector, but I have the same problem. Tried the power+home trick, but no dice. Don't think the battery is short cirquited, but not sure, tried to measure it, only got about 3.6 volt, but unsure where which og the pins to measure on.
I was able to boot the phone before swapping out the dock (wanted to swap it because I had no sound from the speaker plus no wifi antenna due to a ripped cord) but not after swapping back. I've gone over all connections and I am fairly sure everyting is hooked up as it should.
Stuck.
