Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
Cracked both the LCD and Front Panel? This guide shows that replacing the display assembly can be done with ease.
O que você precisa
Vídeo de Apresentação
If your display glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping the glass.
Lay overlapping strips of clear packing tape over the iPhone's display until the whole face is covered.
Remove the two Phillips #00 screws from the dock-connector end of the iPhone.
228 outras pessoas executaram este guia.
Um comentário
i went through the whole process, but my home button does not work anymore. it was fine when I started - its it possible, that one ribbon is not fully attached ore is there any other solution? Thanks for any advice!
Jakob
