Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
Want to replace or take out the camera or your employer requires it? Here's how.
O que você precisa
Insert a SIM card eject tool or paper clip into the hole next to the headphone jack.
Press down on the paper clip until the SIM card tray pops out.
Insert an iPod opening tool in the gap between the antenna cover and the front bezel. The wedge of the tool should be pointing towards the antenna cover. Slide the tool around the corner and up until you reach the metal backing.
Repeat the same procedure on the other side of the dock connector.
Pry up the rear panel by pulling the dental pick clockwise in a quick motion. Apply force perpendicular to the plane of the display assembly. You may be afraid to go fast, but going slowly is more likely to bend the case.
The rear panel is still attached to the iPhone by the headphone jack cable, so don't entirely remove the rear panel from the iPhone just yet.
29 outras pessoas executaram este guia.
