Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
The plastic cover over the antenna on the rear bottom of the iPhone.
O que você precisa
Insert a SIM card eject tool or paper clip into the hole next to the headphone jack.
Press down on the paper clip until the SIM card tray pops out.
Insert an iPod opening tool in the gap between the antenna cover and the front bezel. The wedge of the tool should be pointing towards the antenna cover. Slide the tool around the corner and up until you reach the metal backing.
Repeat the same procedure on the other side of the dock connector.
108 outras pessoas executaram este guia.
3 comentários
I need help I got my iPhone 2g 4gb pulled off the antenna cover and now it won’t go back on please help me!!!
This is very helpful
