Ir para o conteúdo principal
iPhone 13 Pro SIM Card Replacement
O que você precisa
  1. iPhone 13 Pro SIM Card Replacement, Eject the SIM card tray: passo 1, imagem 1 %32 iPhone 13 Pro SIM Card Replacement, Eject the SIM card tray: passo 1, imagem 2 %32 iPhone 13 Pro SIM Card Replacement, Eject the SIM card tray: passo 1, imagem 3 %32
    • Insert a SIM card eject tool into the small hole in the SIM card tray, located on the volume button edge of the iPhone.
    • Press firmly to eject the tray.
  2. iPhone 13 Pro SIM Card Replacement, Remove the SIM card tray: passo 2, imagem 1 %32 iPhone 13 Pro SIM Card Replacement, Remove the SIM card tray: passo 2, imagem 2 %32 iPhone 13 Pro SIM Card Replacement, Remove the SIM card tray: passo 2, imagem 3 %32
    • Remove the SIM card tray from the iPhone.
    • The SIM card will fall out of the tray easily.
    • When reinserting the SIM card, make sure it's in the proper orientation inside the tray.
    • A thin rubber gasket around the SIM tray provides water and dust protection. If this gasket is damaged or missing, replace the gasket or the entire SIM tray to protect your iPhone's internal components.
Conclusão
7 outras pessoas executaram este guia.
Sam Omiotek
Membro desde: 02/25/19
83.715 Reputação
Autoria de 290 guias
3 comentários
I buy iPhone 13 pro but i recieved iPhone 13 pro copy phone,in this phone even I couldn't install sim card , anyone pls help me
Jafar Naikwadi - Responder
Anyone pls help me pls
Hello, can I swap sim card trays from iPhone 13 256 Green to iPhone 14 Pro Max 128 Black (A2894) in EUROPE? I’m guessing they have the same sim card tray shape, I don’t care about the color. Thanks
Stefano Valero - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 12
Últimos 7 dias: 59
Últimos 30 dias: 281
Duração total: 11,730
