Ir para o conteúdo principal
iPhone 11 Pro Rear Case Replacement
O que você precisa
Vídeo de Apresentação
  1. iPhone 11 Pro Rear Case Replacement, Remove the pentalobe screws: passo 1, imagem 1 %32 iPhone 11 Pro Rear Case Replacement, Remove the pentalobe screws: passo 1, imagem 2 %32
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 6.7 mm-long pentalobe screws at the bottom edge of the iPhone.
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
Conclusão
12 outras pessoas executaram este guia.
Arty
Membro desde: 10/27/19
24.510 Reputação
Autoria de 92 guias
3 comentários
how much for housing iphone 11 pro ? Thank you
daddy - Responder
If yo buy it from indonesia it only cost you arround $100-$200
izaz adityas -
I ordered a new charging port but it doesn’t seem to include a speaker element on the left side, and the charging connector module above the port. Can those be moved over from the old charging port?
lemonlev - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 17
Últimos 30 dias: 116
Duração total: 17,067
