Introdução
As we all know, iPhone new series have undergone considerable changes on both inside and outside. Especially on the motherboard. How will these changes affect the repair industry? Will it make third-party repair harder or easier? Find the answer by yourself now.
Vídeo de Apresentação
Compared with iPhone X series, iPhone 11 Pro’s motherboard is smaller with a much denser component array. It is also thicker.
Remove the graphite thermal transfer material with tweezers first.
Place the motherboard on the heating platform to heat for 3 minutes.
Clamp the screws fitted into the screw holes with tweezers and pick up the upper layer with tweezers vertically.
Continue to pick up the lower layer.
Place the lower layer on the heating platform to heat for 10 seconds. Apply some Paste Flux to the third space PCB evenly. Get the upper layer in position and heat for about 5 minutes.
Then, press the SIM card reader with the tweezers and push the upper layer with another tweezers slightly. If the upper layer returns to the previous position automatically, then the soldering process is completed.
- iPhone 11 Series Non-Genuine Screen Warning/Important Display Message - 100% Fix
- '''How To Restore True Tone After Screen Replacement On iPhone XS'''
- '''How to Fix iPhone X Face ID Not Available'''
- '''How to Fix iPhone X Face ID Not Working After Screen Replacement'''
- '''Upgrade iPhone X 64GB Storage To 256GB In 5 Steps'''
- '''How to Restore A Badly Damaged iPhone X'''
- Samsung Galaxy S9/S9+ Cracked Screen Glass Only Repair
- One Solution To Fix 80% iPhone Touch ID Failure
- iPhone 11 Pro Max Cracked Screen Repair - Glass Only
2 outras pessoas concluíram este guia.
