Introdução
Follow the steps in this guide to remove or transfer the earpiece speaker and front sensor assembly in your iPhone 11 Pro Max. This assembly is affixed to the back of the display and includes a microphone, ambient light sensor, flood illuminator, and proximity sensor.
This assembly is paired to your individual iPhone from the factory, so you must transfer it from your old display to your new one during any display replacement.
The flood illuminator forms part of the biometric Face ID security feature, and Face ID functions will fail if the original component is damaged or incorrectly installed. Replacing it with a new part will also cause Face ID to fail, so take extra care not to damage any of these components during this procedure. If damaged, only Apple or an “Apple authorized” technician can restore Face ID function.
O que você precisa
Power off your iPhone before beginning disassembly.
Remove the two 6.7 mm-long pentalobe screws at the bottom edge of the iPhone.
Measure 3 mm from the tip and mark the opening pick with a permanent marker.
Got to step 2 and realized the fix kit doesn't include an opening pick! Looks like a guitar pick, and I have those lying around. Is that expected? Looks like the pick is used in many steps below. There's a little blue crowbar that isn't mentioned in the instructions. Perhaps that replaces the opening pick?
Hi! I can't see which guide you were using when writing this comment. Can you reply here with which guide and fix kit you used?
I see you posted this in Meta. I hope it's resolved soon! In the meantime, a guitar pick may work well enough for your repair.
what fix kit?
My fix kit didn't include an opening pick either
My AliExpress refurbished screen came with a pick that has a coin-like circle that pops out, so no modification was necessary
Lay overlapping strips of clear packing tape over the iPhone's screen until the whole face is covered.
If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the screen with that instead.
Ferramenta utilizada nesse passo:Anti-Clamp
Pull the blue handle backwards to unlock the Anti-Clamp's arms.
Slide the arms over either the left or right edge of your iPhone.
Position the suction cups near the bottom edge of the iPhone—one on the front, and one on the back.
Squeeze the cups together to apply suction to the desired area.
Heat an iOpener and thread it through the arms of the Anti-Clamp.
Fold the iOpener so it lays on the bottom edge of the iPhone.
Wait one minute to give the adhesive a chance to release and present an opening gap.
Insert an opening pick into the gap under the screen and the plastic bezel, not the screen itself.
Skip the next three steps.
Use a hairdryer or heat gun or prepare an iOpener and apply it to the lower edge of the iPhone for about a minute in order to soften up the adhesive underneath.
Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
Insert an opening pick into the gap.
Slide the opening pick around the lower left corner and up the left edge of the iPhone, slicing through the adhesive holding the display in place.
Pull on the small nub on the suction cup to remove it from the front panel.
Open the iPhone by swinging the display up from the left side, like the back cover of a book.
Lean the display against something to keep it propped up while you're working on the phone.
Ferramenta utilizada nesse passo:Magnetic Project Mat$19.95
Remove two 1.3 mm long Y000 screws securing the battery cover bracket.
Use a spudger or a clean fingernail to pry the battery connector up from its socket on the logic board.
Bend the connector slightly away from the logic board to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
The second connection from the battery to the daughterboard should also be disconnected even just as an extra precaution.
Use a Y000 driver to remove six 1.3 mm screws securing the logic board cover bracket.
Solder a paper clip to it
Use a spudger or a fingernail to disconnect the OLED panel cable connector.
Use a spudger or a fingernail to disconnect the front sensor assembly cable connector.
Use a spudger or a fingernail to disconnect the digitizer cable connector.
Remove the three screws securing the speaker/sensor assembly to the back of the display:
Two 1.6 mm Phillips screws
One 1.4 mm Y000 screw
Use the point of a spudger to gently pry up the top edge of the speaker.
Flip the speaker assembly over—down and away from the top edge of the display.
Use a hairdryer or heat gun or prepare an iOpener and apply it to the top front of the display for 1-2 minutes, in order to soften the adhesive securing the sensors.
Use the point of a spudger to lift and separate the microphone from its notch in the front panel.
Use tweezers to wiggle the ambient light sensor and lift it from its notch in the display.
If you successfully removed the entire ambient light sensor, as shown in the first photo, continue to the next step below.
If the white diffuser strip detached and remains embedded in the display, as shown in the second photo, you will need to carefully lever it out along the top edge using a thin blade or pry tool. Re-applying heat first may make this task a bit easier.
Remove the earpiece speaker and front sensor assembly.
Proximity sensor
Flood illuminator
The module must be positioned so that these components are not obstructed by any adhesive.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPhone 11 Pro Max Answers community for help.
17 outras pessoas executaram este guia.
4 comentários
Face id nit conpatible after replacement. Was I supposed to delete the face id previous repair and then set it up again ?!
If you replaced the part face id will not work. If you read the introduction to this guide (above at the top) it tells you this.
Is it possible to replace only the ear piece by soldering a new one? Will face ID still work. Obviosuly if you remove the entire module it won’t work, but what about just the earpeice. I’m aware it wil require desoldering the piece.
I know this is years late bro, but the answer for the next bloke is yes, you can. Just needs soldering tools/skills. There are several Youtube videos with instructions :)
Wie soll mann das Handy ausschalten wenn das Display defekt ist oder nicht angeht?
Elias_Will Diamondblock - Responder
