Ir para o conteúdo principal
iPhone 11 Pentalobe Screws Replacement
O que você precisa
  1. iPhone 11 Pentalobe Screws Replacement, Remove the pentalobe screws: passo 1, imagem 1 %32 iPhone 11 Pentalobe Screws Replacement, Remove the pentalobe screws: passo 1, imagem 2 %32
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 6.7 mm-long pentalobe screws at the bottom edge of the iPhone.
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
Conclusão
12 outras pessoas executaram este guia.
Jeff Suovanen
Membro desde: 08/06/13
427.901 Reputação
Autoria de 259 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 135
Autoria de 16.757 guias
Um comentário
I was putting in a SIM card on my new iPhone 11 and it bounced and I will not find it. Can you send me one or two and a tool to use bc it is so small?
Dah - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 24
Últimos 7 dias: 170
Últimos 30 dias: 662
Duração total: 24,512
