Ir para o conteúdo principal
iPhone 11 Earpiece Speaker and Front Sensor Assembly Replacement
O que você precisa
  1. iPhone 11 Earpiece Speaker and Front Sensor Assembly Replacement, Remove the pentalobe screws: passo 1, imagem 1 %32 iPhone 11 Earpiece Speaker and Front Sensor Assembly Replacement, Remove the pentalobe screws: passo 1, imagem 2 %32
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 6.7 mm-long pentalobe screws at the bottom edge of the iPhone.
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
  2. iPhone 11 Earpiece Speaker and Front Sensor Assembly Replacement, Tape over any cracks: passo 2, imagem 1 %32 iPhone 11 Earpiece Speaker and Front Sensor Assembly Replacement, Tape over any cracks: passo 2, imagem 2 %32 iPhone 11 Earpiece Speaker and Front Sensor Assembly Replacement, Tape over any cracks: passo 2, imagem 3 %32
    • If your iPhone has a cracked screen, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
    • Lay overlapping strips of clear packing tape over the iPhone's screen until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
    • If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the screen with that instead.
    • If all else fails, you can superglue the suction cup to the screen.
  3. iPhone 11 Earpiece Speaker and Front Sensor Assembly Replacement, Anti-Clamp instructions: passo 3, imagem 1 %32 iPhone 11 Earpiece Speaker and Front Sensor Assembly Replacement, Anti-Clamp instructions: passo 3, imagem 2 %32 iPhone 11 Earpiece Speaker and Front Sensor Assembly Replacement, Anti-Clamp instructions: passo 3, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Anti-Clamp
    $24.95
    Comprar
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone—one on the top, and one on the bottom.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  4. iPhone 11 Earpiece Speaker and Front Sensor Assembly Replacement: passo 4, imagem 1 %32 iPhone 11 Earpiece Speaker and Front Sensor Assembly Replacement: passo 4, imagem 2 %32 iPhone 11 Earpiece Speaker and Front Sensor Assembly Replacement: passo 4, imagem 3 %32
    • Pull the blue handle forward to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  5. iPhone 11 Earpiece Speaker and Front Sensor Assembly Replacement: passo 5, imagem 1 %32 iPhone 11 Earpiece Speaker and Front Sensor Assembly Replacement: passo 5, imagem 2 %32 iPhone 11 Earpiece Speaker and Front Sensor Assembly Replacement: passo 5, imagem 3 %32
    • Heat an iOpener and thread it through the arms of the Anti-Clamp.
    • You can also use a hair dryer, heat gun, or hot plate—but extreme heat can damage the display and/or internal battery, so proceed with care.
    • Fold the iOpener so it lays on the bottom edge of the iPhone.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick into the gap under the screen and the plastic bezel, not the screen itself.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next three steps.
  6. iPhone 11 Earpiece Speaker and Front Sensor Assembly Replacement, Heat the lower edge of the phone: passo 6, imagem 1 %32
    • Heating the lower edge of the iPhone helps soften the adhesive securing the display, making it easier to open.
    • Use a hairdryer or heat gun or prepare an iOpener and apply it to the lower edge of the iPhone for about a minute.
  7. iPhone 11 Earpiece Speaker and Front Sensor Assembly Replacement: passo 7, imagem 1 %32 iPhone 11 Earpiece Speaker and Front Sensor Assembly Replacement: passo 7, imagem 2 %32
    • If you're using a single suction handle, apply it to the bottom edge of the phone, while avoiding the curved portion of the glass.
  8. iPhone 11 Earpiece Speaker and Front Sensor Assembly Replacement, Lift the display slightly: passo 8, imagem 1 %32 iPhone 11 Earpiece Speaker and Front Sensor Assembly Replacement, Lift the display slightly: passo 8, imagem 2 %32 iPhone 11 Earpiece Speaker and Front Sensor Assembly Replacement, Lift the display slightly: passo 8, imagem 3 %32
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
    • Insert an opening pick into the gap under the screen and the plastic bezelnot the screen itself.
    • The watertight adhesive holding the display in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
  9. iPhone 11 Earpiece Speaker and Front Sensor Assembly Replacement, Separate the screen adhesive: passo 9, imagem 1 %32 iPhone 11 Earpiece Speaker and Front Sensor Assembly Replacement, Separate the screen adhesive: passo 9, imagem 2 %32 iPhone 11 Earpiece Speaker and Front Sensor Assembly Replacement, Separate the screen adhesive: passo 9, imagem 3 %32
    • Slide the opening pick around the lower left corner and up the left edge of the iPhone, slicing through the adhesive holding the display in place.
    • Don't insert your pick more than 3 mm, as you may damage internal components.
  10. iPhone 11 Earpiece Speaker and Front Sensor Assembly Replacement, Screen information: passo 10, imagem 1 %32
    • There are delicate cables along the right edge of your iPhone. Don't insert your pick here, as you may damage the cables.
  11. iPhone 11 Earpiece Speaker and Front Sensor Assembly Replacement: passo 11, imagem 1 %32 iPhone 11 Earpiece Speaker and Front Sensor Assembly Replacement: passo 11, imagem 2 %32 iPhone 11 Earpiece Speaker and Front Sensor Assembly Replacement: passo 11, imagem 3 %32
    • Re-insert your pick at the bottom edge of the iPhone, and slide it up the right side to continue separating the adhesive.
    • Don't insert your pick more than 3 mm, as you may damage the display cables.
  12. iPhone 11 Earpiece Speaker and Front Sensor Assembly Replacement: passo 12, imagem 1 %32 iPhone 11 Earpiece Speaker and Front Sensor Assembly Replacement: passo 12, imagem 2 %32 iPhone 11 Earpiece Speaker and Front Sensor Assembly Replacement: passo 12, imagem 3 %32
    • The top edge of the display is secured with both glue and clips.
    • Gently pull the right edge of the display down slightly (in the direction of the Lightning port).
    • Insert your pick into the top-right corner of the phone.
  13. iPhone 11 Earpiece Speaker and Front Sensor Assembly Replacement: passo 13, imagem 1 %32 iPhone 11 Earpiece Speaker and Front Sensor Assembly Replacement: passo 13, imagem 2 %32
    • Continue pulling the display down (toward the Lightning port) as needed in order to make a gap large enough for the pick.
    • Slide the pick to the top left corner and cut any remaining adhesive securing the display.
    • Don't insert your pick more than 3 mm, as you may damage the Face ID sensor array.
  14. iPhone 11 Earpiece Speaker and Front Sensor Assembly Replacement, Remove the suction cup: passo 14, imagem 1 %32
    • Pull the small nub on the suction cup to detach it from the front panel.
  15. iPhone 11 Earpiece Speaker and Front Sensor Assembly Replacement, Open the iPhone: passo 15, imagem 1 %32 iPhone 11 Earpiece Speaker and Front Sensor Assembly Replacement, Open the iPhone: passo 15, imagem 2 %32 iPhone 11 Earpiece Speaker and Front Sensor Assembly Replacement, Open the iPhone: passo 15, imagem 3 %32
    • Open the iPhone by swinging the display up from the left side, like the back cover of a book.
    • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
    • Prop the display up against something sturdy.
    • During reassembly, lay the display in position, align the clips along the top edge, and carefully press the top edge into place before snapping the rest of the display down. If it doesn't click easily into place, check the condition of the clips around the perimeter of the display and make sure they aren't bent.
  16. iPhone 11 Earpiece Speaker and Front Sensor Assembly Replacement, Display Assembly: passo 16, imagem 1 %32 iPhone 11 Earpiece Speaker and Front Sensor Assembly Replacement, Display Assembly: passo 16, imagem 2 %32
    • To access the screws in the following step, tilt the display by slightly lifting its lower edge.
    • Be careful not to strain or tear the display cables.
  17. iPhone 11 Earpiece Speaker and Front Sensor Assembly Replacement, Unscrew the battery connector cover: passo 17, imagem 1 %32 iPhone 11 Earpiece Speaker and Front Sensor Assembly Replacement, Unscrew the battery connector cover: passo 17, imagem 2 %32
    Magnetic Project Mat
    $19.95
    Comprar
    • Use a Y000 driver to remove the three 1.1 mm-long screws securing the battery connector bracket.
    • During reassembly, this is a good point to power on your iPhone and test all functions before you seal the display in place. Be sure to power your iPhone back down completely before you continue working.
  18. iPhone 11 Earpiece Speaker and Front Sensor Assembly Replacement, Remove the battery connector cover: passo 18, imagem 1 %32
    • Remove the bracket.
  19. iPhone 11 Earpiece Speaker and Front Sensor Assembly Replacement, Disconnect the battery: passo 19, imagem 1 %32 iPhone 11 Earpiece Speaker and Front Sensor Assembly Replacement, Disconnect the battery: passo 19, imagem 2 %32
    • Use a spudger or a clean fingernail to pry the battery connector up from its socket on the logic board.
    • Try not to damage the black silicone seal surrounding this and other board connections. These seals provide extra protection against water and dust intrusion.
    • Bend the connector slightly away from the logic board to prevent it from accidentally contacting the socket.
  20. iPhone 11 Earpiece Speaker and Front Sensor Assembly Replacement, Unscrew the logic board cover screws: passo 20, imagem 1 %32 iPhone 11 Earpiece Speaker and Front Sensor Assembly Replacement, Unscrew the logic board cover screws: passo 20, imagem 2 %32
    • Use a Y000 driver to remove the five 1.1 mm screws securing the logic board cover bracket.
  21. iPhone 11 Earpiece Speaker and Front Sensor Assembly Replacement, Remove the logic board cover bracket: passo 21, imagem 1 %32
  22. iPhone 11 Earpiece Speaker and Front Sensor Assembly Replacement, Disconnect the display: passo 22, imagem 1 %32 iPhone 11 Earpiece Speaker and Front Sensor Assembly Replacement, Disconnect the display: passo 22, imagem 2 %32 iPhone 11 Earpiece Speaker and Front Sensor Assembly Replacement, Disconnect the display: passo 22, imagem 3 %32
    • Use a spudger or a fingernail to disconnect the LCD panel cable connector.
    • Disconnect the digitizer connector next to it.
  23. iPhone 11 Earpiece Speaker and Front Sensor Assembly Replacement, Disconnect the front sensors: passo 23, imagem 1 %32 iPhone 11 Earpiece Speaker and Front Sensor Assembly Replacement, Disconnect the front sensors: passo 23, imagem 2 %32
    • Use the point of a spudger or a fingernail to disconnect the front panel sensor assembly connector.
  24. iPhone 11 Earpiece Speaker and Front Sensor Assembly Replacement, Remove the display assembly: passo 24, imagem 1 %32
  25. iPhone 11 Earpiece Speaker and Front Sensor Assembly Replacement, Unscrew the front assembly: passo 25, imagem 1 %32
    • Remove four screws securing the speaker/sensor assembly:
    • Three 1.6 mm Phillips screws
    • One 1.3 mm Y000 screw
  26. iPhone 11 Earpiece Speaker and Front Sensor Assembly Replacement, Flip the speaker assembly over: passo 26, imagem 1 %32 iPhone 11 Earpiece Speaker and Front Sensor Assembly Replacement, Flip the speaker assembly over: passo 26, imagem 2 %32 iPhone 11 Earpiece Speaker and Front Sensor Assembly Replacement, Flip the speaker assembly over: passo 26, imagem 3 %32
    • Use the point of a spudger to gently pry up the top edge of the speaker.
    • Flip the speaker assembly over—down and away from the top edge of the display.
    • The speaker remains attached via very thin ribbon cables. Be careful not to strain or damage the cables.
  27. iPhone 11 Earpiece Speaker and Front Sensor Assembly Replacement, Heat up the top edge of the display: passo 27, imagem 1 %32
    • Use a hairdryer or heat gun or prepare an iOpener and apply it to the top front of the display for 1-2 minutes, in order to soften the adhesive securing the sensors.
  28. iPhone 11 Earpiece Speaker and Front Sensor Assembly Replacement, Pry up the microphone: passo 28, imagem 1 %32 iPhone 11 Earpiece Speaker and Front Sensor Assembly Replacement, Pry up the microphone: passo 28, imagem 2 %32 iPhone 11 Earpiece Speaker and Front Sensor Assembly Replacement, Pry up the microphone: passo 28, imagem 3 %32
    • Carefully slide the edge of your opening pick underneath the flex cable below the microphone.
    • Twist gently to separate the microphone, while being careful not to strain or damage the flex cable.
    • If needed, use the point of the spudger to finish separating the microphone from its notch in the front panel.
  29. iPhone 11 Earpiece Speaker and Front Sensor Assembly Replacement, Remove the ambient light sensor bracket: passo 29, imagem 1 %32 iPhone 11 Earpiece Speaker and Front Sensor Assembly Replacement, Remove the ambient light sensor bracket: passo 29, imagem 2 %32
    • Use tweezers to slide the small bracket straight up and off of the ambient light sensor.
  30. iPhone 11 Earpiece Speaker and Front Sensor Assembly Replacement, Loosen the ambient light sensor: passo 30, imagem 1 %32 iPhone 11 Earpiece Speaker and Front Sensor Assembly Replacement, Loosen the ambient light sensor: passo 30, imagem 2 %32
    • Use tweezers to wiggle the ambient light sensor and lift it from its notch in the display.
    • If the sensor does not wiggle free after a few seconds, apply more heat and try again.
    • The sensor remains attached to the rest of the sensor assembly via a very thin flex cable. Be careful not to strain or damage the cable.
  31. iPhone 11 Earpiece Speaker and Front Sensor Assembly Replacement: passo 31, imagem 1 %32 iPhone 11 Earpiece Speaker and Front Sensor Assembly Replacement: passo 31, imagem 2 %32 iPhone 11 Earpiece Speaker and Front Sensor Assembly Replacement: passo 31, imagem 3 %32
    • Working left to right, slide an opening pick beneath the flex cable and underneath the proximity sensor + flood illuminator module.
    • Gently wiggle and lift to separate the module from its notch in the front panel.
    • It's helpful to lift and hold the speaker out of the way for access. Just be careful not to pull on the thin flex cable while you work.
  32. iPhone 11 Earpiece Speaker and Front Sensor Assembly Replacement, Remove the speaker + front sensors: passo 32, imagem 1 %32 iPhone 11 Earpiece Speaker and Front Sensor Assembly Replacement, Remove the speaker + front sensors: passo 32, imagem 2 %32 iPhone 11 Earpiece Speaker and Front Sensor Assembly Replacement, Remove the speaker + front sensors: passo 32, imagem 3 %32
    • Remove the earpiece speaker and front sensor assembly.
    • During reassembly, check the position of the black plastic module containing these components:
    • Proximity sensor
    • Flood illuminator
    • The module must be positioned so that these components are not obstructed by any adhesive.
Conclusão
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPhone 11 Answers community for help.
22 outras pessoas executaram este guia.
Jeff Suovanen
Membro desde: 08/06/13
427.796 Reputação
Autoria de 259 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 135
Autoria de 16.718 guias
9 comentários
What happens if you don’t remove the front speaker and sensors before the screen replacement? If you miss this step, after replacing the screen, can you use the same replacement screen and start over?
Thanks
Chuck Evans - Responder
Hi Chuck,
Without the original front sensors, your Face ID will not work, as the components are paired to the logic board.
Arthur Shi -
Thanks, I have the original broken front screen. I’ll take that off and put it on the new screen.
I have put the original speaker/camera/sensors on the new screen but still, get a phone that won’t turn on. I have tried 3 different iPhone 11’s and get the same result with each! They all worked fine, except for cracked screens, before I put on the new screens. I put Incell FX5 on each of them. Now, none of them will ower on. Any suggestions? Thanks!
I bought a SWAPIE iPhone11 and the microphon is a disaster. is it true that they are using low budget replacement?!
Francisco Lopez Martinez - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 68
Últimos 7 dias: 418
Últimos 30 dias: 1,677
Duração total: 58,793
