Ir para o conteúdo principal
iPad mini 5 Wi-Fi Home Button Assembly Replacement
O que você precisa
  1. iPad mini 5 Wi-Fi Home Button Assembly Replacement, Apply tape to a cracked screen: passo 1, imagem 1 %32 iPad mini 5 Wi-Fi Home Button Assembly Replacement, Apply tape to a cracked screen: passo 1, imagem 2 %32 iPad mini 5 Wi-Fi Home Button Assembly Replacement, Apply tape to a cracked screen: passo 1, imagem 3 %32
    • Lay overlapping strips of clear packing tape over the iPad's display until the whole face is covered.
    • Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
    • Wear safety glasses to protect your eyes, and be careful not to damage the LCD screen.
  2. iPad mini 5 Wi-Fi Home Button Assembly Replacement, Opening Procedure: passo 2, imagem 1 %32
  3. iPad mini 5 Wi-Fi Home Button Assembly Replacement: passo 3, imagem 1 %32 iPad mini 5 Wi-Fi Home Button Assembly Replacement: passo 3, imagem 2 %32 iPad mini 5 Wi-Fi Home Button Assembly Replacement: passo 3, imagem 3 %32
    • Apply a suction cup halfway up the heated side.
    • Be sure the cup is completely flat on the screen to get a tight seal.
    • While holding the iPad down with one hand, pull up on the suction cup with strong, steady force to create a gap.
    • Depending on the age of your device, this may be difficult. If you have trouble, apply more heat and try again.
    • Be careful to only lift the glass enough to insert an opening pick—any more and you risk cracking the glass.
  4. iPad mini 5 Wi-Fi Home Button Assembly Replacement: passo 4, imagem 1 %32 iPad mini 5 Wi-Fi Home Button Assembly Replacement: passo 4, imagem 2 %32
    • While holding the glass up with the suction cup, insert the point of an opening pick into the gap between the glass and body of the iPad.
    • Don't insert the opening pick any deeper than 2 mm into the side of the display. Inserting the pick deeper than 2 mm could damage the backlight assembly, LCD display, or touchscreen.
  5. iPad mini 5 Wi-Fi Home Button Assembly Replacement: passo 5, imagem 1 %32
    • Reheat and reapply the iOpener to the left edge for a few minutes.
    • Be careful not to overheat the iOpener during the repair procedure. Always wait at least ten minutes before reheating the iOpener.
  6. iPad mini 5 Wi-Fi Home Button Assembly Replacement: passo 6, imagem 1 %32 iPad mini 5 Wi-Fi Home Button Assembly Replacement: passo 6, imagem 2 %32 iPad mini 5 Wi-Fi Home Button Assembly Replacement: passo 6, imagem 3 %32
    • Insert a second opening pick alongside the first and slide the pick down along the edge of the iPad, releasing the adhesive as you go.
    • Throughout the rest of the procedure, if you encounter significant resistance while sliding the pick, stop and reheat the section you're working on. Applying too much pressure with the pick can crack the glass.
  7. iPad mini 5 Wi-Fi Home Button Assembly Replacement: passo 7, imagem 1 %32 iPad mini 5 Wi-Fi Home Button Assembly Replacement: passo 7, imagem 2 %32 iPad mini 5 Wi-Fi Home Button Assembly Replacement: passo 7, imagem 3 %32
    • Continue moving the opening pick down the side of the display to release the adhesive.
    • If the opening pick gets stuck in the adhesive, "roll" the pick along the side of the iPad, continuing to release the adhesive.
  8. iPad mini 5 Wi-Fi Home Button Assembly Replacement: passo 8, imagem 1 %32 iPad mini 5 Wi-Fi Home Button Assembly Replacement: passo 8, imagem 2 %32
    • Take the first pick you inserted and slide it up toward the top corner of the iPad.
  9. iPad mini 5 Wi-Fi Home Button Assembly Replacement: passo 9, imagem 1 %32
    • Reheat the iOpener and place it on the top edge of the iPad, over the front-facing camera.
    • Be careful not to overheat the iOpener during the repair procedure. Wait at least ten minutes before reheating the iOpener.
    • If you have a flexible iOpener, you can bend it to heat both the upper left corner and the upper edge at the same time.
  10. iPad mini 5 Wi-Fi Home Button Assembly Replacement: passo 10, imagem 1 %32 iPad mini 5 Wi-Fi Home Button Assembly Replacement: passo 10, imagem 2 %32 iPad mini 5 Wi-Fi Home Button Assembly Replacement: passo 10, imagem 3 %32
    • Slide the opening pick around the top left corner of the iPad to separate the adhesive.
  11. iPad mini 5 Wi-Fi Home Button Assembly Replacement: passo 11, imagem 1 %32 iPad mini 5 Wi-Fi Home Button Assembly Replacement: passo 11, imagem 2 %32 iPad mini 5 Wi-Fi Home Button Assembly Replacement: passo 11, imagem 3 %32
    • Slide the opening pick along the top edge of the iPad, stopping just before you reach the camera.
    • As you reach the front-facing camera, pull the pick out slightly and continue sliding it across the top edge.
    • Avoid sliding the opening pick over the front-facing camera, as you may smear adhesive onto the lens or damage the camera. The following steps will detail how to best avoid disturbing the front-facing camera.
  12. iPad mini 5 Wi-Fi Home Button Assembly Replacement: passo 12, imagem 1 %32 iPad mini 5 Wi-Fi Home Button Assembly Replacement: passo 12, imagem 2 %32 iPad mini 5 Wi-Fi Home Button Assembly Replacement: passo 12, imagem 3 %32
    • Leave the opening pick in the iPad slightly past the front-facing camera.
    • Take a second pick and insert it to the left of the camera, where the first pick just was. Slide it back to the corner to completely cut any remaining adhesive.
    • Leave the second pick in place to prevent the corner adhesive from re-sealing as it cools.
  13. iPad mini 5 Wi-Fi Home Button Assembly Replacement: passo 13, imagem 1 %32 iPad mini 5 Wi-Fi Home Button Assembly Replacement: passo 13, imagem 2 %32
    • Insert the previous pick deeper into the iPad and slide it away from the camera toward the corner.
  14. iPad mini 5 Wi-Fi Home Button Assembly Replacement: passo 14, imagem 1 %32
    • Leave the three picks in the corners of the iPad to prevent re-adhering of the front panel adhesive.
    • Reheat the iOpener and place it on the remaining long side of the iPad—along the volume and lock buttons.
  15. iPad mini 5 Wi-Fi Home Button Assembly Replacement: passo 15, imagem 1 %32 iPad mini 5 Wi-Fi Home Button Assembly Replacement: passo 15, imagem 2 %32 iPad mini 5 Wi-Fi Home Button Assembly Replacement: passo 15, imagem 3 %32
    • Insert a new opening pick and slide it down the right edge of the iPad, releasing the adhesive as you go.
  16. iPad mini 5 Wi-Fi Home Button Assembly Replacement: passo 16, imagem 1 %32 iPad mini 5 Wi-Fi Home Button Assembly Replacement: passo 16, imagem 2 %32 iPad mini 5 Wi-Fi Home Button Assembly Replacement: passo 16, imagem 3 %32
    • Continue sliding the opening pick down the right edge of the iPad, reheating the edge using an iOpener if necessary.
    • Be careful not to slice too deep near the bottom right corner, or you risk damaging the display cable.
  17. iPad mini 5 Wi-Fi Home Button Assembly Replacement: passo 17, imagem 1 %32
    • Leave the opening picks in place and reheat the iOpener.
    • Remember not to overheat the iOpener—no more than once every ten minutes.
    • Set the reheated iOpener on the home button end of the iPad and let it rest for a few minutes to soften the adhesive beneath the glass.
  18. iPad mini 5 Wi-Fi Home Button Assembly Replacement: passo 18, imagem 1 %32 iPad mini 5 Wi-Fi Home Button Assembly Replacement: passo 18, imagem 2 %32 iPad mini 5 Wi-Fi Home Button Assembly Replacement: passo 18, imagem 3 %32
    • Insert a new opening pick at the bottom right corner of the display, below the last opening pick you used to slice down the right edge.
    • Rotate the new pick around the lower right corner of the device.
  19. iPad mini 5 Wi-Fi Home Button Assembly Replacement: passo 19, imagem 1 %32 iPad mini 5 Wi-Fi Home Button Assembly Replacement: passo 19, imagem 2 %32
    • Slide the pick from the bottom right corner along the lower edge of the device. Stop about half an inch shy of the home button.
  20. iPad mini 5 Wi-Fi Home Button Assembly Replacement: passo 20, imagem 1 %32 iPad mini 5 Wi-Fi Home Button Assembly Replacement: passo 20, imagem 2 %32
    • Insert a final opening pick at the lower left corner of the iPad, directly below the existing one.
  21. iPad mini 5 Wi-Fi Home Button Assembly Replacement: passo 21, imagem 1 %32 iPad mini 5 Wi-Fi Home Button Assembly Replacement: passo 21, imagem 2 %32
    • Slide the pick around the lower left edge of the iPad.
  22. iPad mini 5 Wi-Fi Home Button Assembly Replacement: passo 22, imagem 1 %32 iPad mini 5 Wi-Fi Home Button Assembly Replacement: passo 22, imagem 2 %32 iPad mini 5 Wi-Fi Home Button Assembly Replacement: passo 22, imagem 3 %32
    • Continue sliding the pick at the lower left edge of the display toward the center of the iPad, until it is roughly half an inch from the home button.
  23. iPad mini 5 Wi-Fi Home Button Assembly Replacement: passo 23, imagem 1 %32 iPad mini 5 Wi-Fi Home Button Assembly Replacement: passo 23, imagem 2 %32 iPad mini 5 Wi-Fi Home Button Assembly Replacement: passo 23, imagem 3 %32
    • Twist the two picks at the top edge of the iPad to break up the last of the adhesive holding the display assembly in place.
    • Lift the display from the top edge to open the device.
  24. iPad mini 5 Wi-Fi Home Button Assembly Replacement, Hold the screen perpendicular: passo 24, imagem 1 %32
    • To avoid stressing any cables, hold the screen perpendicular to the frame.
  25. iPad mini 5 Wi-Fi Home Button Assembly Replacement, Remove the display cable bracket: passo 25, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Magnetic Project Mat
    $19.95
    Comprar
    • Continue to hold the screen perpendicular during this step.
    • Use a Phillips screwdriver to remove the two 1.3 mm screws securing the display cable bracket.
  26. iPad mini 5 Wi-Fi Home Button Assembly Replacement, Reposition the screen: passo 26, imagem 1 %32
    • You'll need to reposition the screen to access the bottom side of the display cable bracket.
    • Lower the screen to about 30 degrees above the frame.
  27. iPad mini 5 Wi-Fi Home Button Assembly Replacement, Disconnect the battery: passo 27, imagem 1 %32 iPad mini 5 Wi-Fi Home Button Assembly Replacement, Disconnect the battery: passo 27, imagem 2 %32
    • The battery press connector is attached to the underside of the display cable bracket on the screw hole side.
    • Insert the flat end of a spudger under the display cable bracket and lift up to disconnect the battery press connector from the logic board.
    • Take care to pry only under the edge of the connector to prevent damaging the socket itself and surrounding components.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
    • Don't try to remove the display cable bracket as it's attached to the battery by the battery cable.
  28. iPad mini 5 Wi-Fi Home Button Assembly Replacement, Rotate the display cable bracket: passo 28, imagem 1 %32 iPad mini 5 Wi-Fi Home Button Assembly Replacement, Rotate the display cable bracket: passo 28, imagem 2 %32 iPad mini 5 Wi-Fi Home Button Assembly Replacement, Rotate the display cable bracket: passo 28, imagem 3 %32
    • The display cable bracket is secured by a clip under the edge of the frame.
    • Use a pair of tweezers to pull the display cable bracket's clip out from under the frame's edge.
    • Rotate the display cable bracket toward the battery.
    • Don't bend the battery cable too much past vertical to avoid damaging it. You only need enough space to disconnect the display press connectors and prevent the battery connector from making contact with its socket during the repair.
  29. iPad mini 5 Wi-Fi Home Button Assembly Replacement, Disconnect the display press connectors: passo 29, imagem 1 %32 iPad mini 5 Wi-Fi Home Button Assembly Replacement, Disconnect the display press connectors: passo 29, imagem 2 %32
    • Use the pointed end of a spudger to disconnect the digitizer press connector from the logic board.
  30. iPad mini 5 Wi-Fi Home Button Assembly Replacement: passo 30, imagem 1 %32 iPad mini 5 Wi-Fi Home Button Assembly Replacement: passo 30, imagem 2 %32 iPad mini 5 Wi-Fi Home Button Assembly Replacement: passo 30, imagem 3 %32
    • Use the pointed end of a spudger to disconnect the second and third display press connectors.
  31. iPad mini 5 Wi-Fi Home Button Assembly Replacement, Remove the screen: passo 31, imagem 1 %32
    • Lift and remove the screen.
  32. iPad mini 5 Wi-Fi Home Button Assembly Replacement, Screen reassembly information: passo 32, imagem 1 %32 iPad mini 5 Wi-Fi Home Button Assembly Replacement, Screen reassembly information: passo 32, imagem 2 %32 iPad mini 5 Wi-Fi Home Button Assembly Replacement, Screen reassembly information: passo 32, imagem 3 %32
    • During reassembly, remove any remaining adhesive and residue from the perimeters of the frame and the screen. Then, apply new adhesive to secure the screen to the frame.
    • Don't remove the black tape on the left, right, and upper edges of the display. These hold the display to the front glass.
    • Follow this guide if you are using a pre-cut adhesive card. Follow this guide if you are using custom-cut adhesives.
  33. iPad mini 5 Wi-Fi Home Button Assembly Replacement, Remove the ZIF connector sticker: passo 33, imagem 1 %32 iPad mini 5 Wi-Fi Home Button Assembly Replacement, Remove the ZIF connector sticker: passo 33, imagem 2 %32
    • Use a pair of tweezers to remove the sticker covering the home button assembly ZIF connector.
  34. iPad mini 5 Wi-Fi Home Button Assembly Replacement, Unlock the ZIF connector: passo 34, imagem 1 %32 iPad mini 5 Wi-Fi Home Button Assembly Replacement, Unlock the ZIF connector: passo 34, imagem 2 %32
    • Use the pointed end of a spudger, an opening tool, or your fingernail to flip up the small, hinged locking flap on the home button assembly ZIF connector.
  35. iPad mini 5 Wi-Fi Home Button Assembly Replacement, Unplug the home button assembly ZIF connector: passo 35, imagem 1 %32 iPad mini 5 Wi-Fi Home Button Assembly Replacement, Unplug the home button assembly ZIF connector: passo 35, imagem 2 %32
    • Use a pair of tweezers to pull the home button assembly cable out of the ZIF connector.
  36. iPad mini 5 Wi-Fi Home Button Assembly Replacement, Separate the home button assembly cable: passo 36, imagem 1 %32 iPad mini 5 Wi-Fi Home Button Assembly Replacement, Separate the home button assembly cable: passo 36, imagem 2 %32
    • The home button assembly cable is secured to the screen with light adhesive.
    • Use an opening pick to separate the home button assembly cable from the screen.
  37. iPad mini 5 Wi-Fi Home Button Assembly Replacement: passo 37, imagem 1 %32 iPad mini 5 Wi-Fi Home Button Assembly Replacement: passo 37, imagem 2 %32 iPad mini 5 Wi-Fi Home Button Assembly Replacement: passo 37, imagem 3 %32
    • Use an opening pick to continue separating the home button assembly cable from the screen.
  38. iPad mini 5 Wi-Fi Home Button Assembly Replacement, Pry off the home button bracket: passo 38, imagem 1 %32 iPad mini 5 Wi-Fi Home Button Assembly Replacement, Pry off the home button bracket: passo 38, imagem 2 %32 iPad mini 5 Wi-Fi Home Button Assembly Replacement, Pry off the home button bracket: passo 38, imagem 3 %32
    E6000 Adhesive Glue
    $2.99
    Comprar
    • Use a plastic opening tool to pry the home button bracket off of the screen.
    • Use a pair of tweezers to lift and remove the home button bracket.
    • When reinstalling this bracket, use high bond glue such as E6000 to secure it to the screen.
    • Use a small clamp to hold the bracket to the screen during the curing duration.
    • Make sure to support the other edges of the screen while clamping the bracket to avoid breaking the screen.
  39. iPad mini 5 Wi-Fi Home Button Assembly Replacement, Heat the bottom of the screen: passo 39, imagem 1 %32
    • Heat an iOpener and apply it to the bottom of the screen for two minutes to weaken the adhesive holding the home button in place.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the display—it is susceptible to heat damage.
  40. iPad mini 5 Wi-Fi Home Button Assembly Replacement, Remove the home button assembly: passo 40, imagem 1 %32 iPad mini 5 Wi-Fi Home Button Assembly Replacement, Remove the home button assembly: passo 40, imagem 2 %32
    • The home button is held in place by a thin, delicate rubber gasket that is lightly adhered to the screen.
    • Slowly push the home button up and out through the back of the screen.
    • The home button will be hot. Wait until it's cool enough to touch before pushing it up.
    • Be careful to not push the gasket past its tearing point. If the adhesive is adequately heated, it will separate with gentle pressure.
  41. iPad mini 5 Wi-Fi Home Button Assembly Replacement: passo 41, imagem 1 %32 iPad mini 5 Wi-Fi Home Button Assembly Replacement: passo 41, imagem 2 %32 iPad mini 5 Wi-Fi Home Button Assembly Replacement: passo 41, imagem 3 %32
    • Lift and remove the home button assembly.
    • You can reuse the home button gasket if it's sufficiently tacky. Otherwise, replace the black rubber gasket:
    • Peel the gasket off of the home button. Then, thread it past the cable to remove it.
    • Apply a replacement gasket to the home button.
    • The iPad mini 4's replacement gasket fits on the iPad mini 5, but it is slightly larger. Make sure it doesn't overlap the screen's adhesive so that the screen can be properly adhered to the frame.
    • To install the home button:
    • Rotate the home button so that the home button cable sits where it was before disassembly. Make sure the home button cable can be inserted into its ZIF connector.
    • Center the home button so that it fits into its slot in the screen. Then, press down firmly on the gasket to adhere it to the screen.
Conclusão
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPad mini 5 Answers community for help.
Uma outra pessoa concluiu este guia.
Kyle Smith
Membro desde: 02/01/21
40.899 Reputação
Autoria de 123 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 23
Últimos 30 dias: 155
Duração total: 3,441
