Ir para o conteúdo principal
Introdução
Prerequisite guide for accessing upper components in an iPad mini 4 LTE.
Peças
Nenhum componente especificado.
  1. Run the pointed end of a spudger between the looped tape and the plastic cellular antenna housing to make it easier to peel the tape up. Run the pointed end of a spudger between the looped tape and the plastic cellular antenna housing to make it easier to peel the tape up.
    • Run the pointed end of a spudger between the looped tape and the plastic cellular antenna housing to make it easier to peel the tape up.
  2. Use tweezers to peel up the looped tape adhered over the upper component cable bracket. Use tweezers to peel up the looped tape adhered over the upper component cable bracket. Use tweezers to peel up the looped tape adhered over the upper component cable bracket.
    • Use tweezers to peel up the looped tape adhered over the upper component cable bracket.
  3. Remove the following four Phillips screws holding the upper component bracket in place:
    • Remove the following four Phillips screws holding the upper component bracket in place:
    • Two 2.1 mm screws
    • Two 1.2 mm screws
  4. Remove the upper component cable bracket.
    • Remove the upper component cable bracket.
Conclusão
Evan Noronha
Membro desde: 05/02/2015
206.375 Reputação
178 Guias de autoria
Equipe
iFixit Membro de iFixit
Community
136 Membros
16.000 Guias de autoria
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 42
