Ir para o conteúdo principal
iPad mini 4 LTE Logic Board Replacement
O que você precisa
  1. iPad mini 4 LTE Logic Board Replacement, Taping a Cracked Front Panel: passo 1, imagem 1 %32 iPad mini 4 LTE Logic Board Replacement, Taping a Cracked Front Panel: passo 1, imagem 2 %32 iPad mini 4 LTE Logic Board Replacement, Taping a Cracked Front Panel: passo 1, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Safety Glasses
    $3.19
    Comprar
    • Lay overlapping strips of clear packing tape over the iPad's display until the whole face is covered. For particularly bad breaks, you may need to lay down two layers.
    • Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
    • Protect your eyes! This procedure will cause small pieces of glass to fly directly toward your face. Do not attempt without safety glasses.
  2. iPad mini 4 LTE Logic Board Replacement, Opening Procedure: passo 2, imagem 1 %32
  3. iPad mini 4 LTE Logic Board Replacement: passo 3, imagem 1 %32 iPad mini 4 LTE Logic Board Replacement: passo 3, imagem 2 %32 iPad mini 4 LTE Logic Board Replacement: passo 3, imagem 3 %32
    • Apply a suction cup halfway up the heated side.
    • Be sure the cup is completely flat on the screen to get a tight seal.
    • While holding the iPad down with one hand, pull up on the suction cup with strong, steady force to create a gap.
    • Depending on the age of your device, this may be difficult. If you have trouble, apply more heat and try again.
    • Be careful to only lift the glass enough to insert an opening pick—any more and you risk cracking the glass.
  4. iPad mini 4 LTE Logic Board Replacement: passo 4, imagem 1 %32 iPad mini 4 LTE Logic Board Replacement: passo 4, imagem 2 %32
    • While holding the glass up with the suction cup, insert the point of an opening pick into the gap between the glass and body of the iPad.
    • Don't insert the opening pick any deeper than 2 mm into the side of the display. Inserting the pick deeper than 2 mm could damage the backlight assembly, LCD display, or touchscreen.
  5. iPad mini 4 LTE Logic Board Replacement: passo 5, imagem 1 %32
    • Reheat and reapply the iOpener to the left edge for a few minutes.
    • Be careful not to overheat the iOpener during the repair procedure. Always wait at least ten minutes before reheating the iOpener.
  6. iPad mini 4 LTE Logic Board Replacement: passo 6, imagem 1 %32 iPad mini 4 LTE Logic Board Replacement: passo 6, imagem 2 %32 iPad mini 4 LTE Logic Board Replacement: passo 6, imagem 3 %32
    • Insert a second opening pick alongside the first and slide the pick down along the edge of the iPad, releasing the adhesive as you go.
    • Throughout the rest of the procedure, if you encounter significant resistance while sliding the pick, stop and reheat the section you're working on. Applying too much pressure with the pick can crack the glass.
  7. iPad mini 4 LTE Logic Board Replacement: passo 7, imagem 1 %32 iPad mini 4 LTE Logic Board Replacement: passo 7, imagem 2 %32 iPad mini 4 LTE Logic Board Replacement: passo 7, imagem 3 %32
    • Continue moving the opening pick down the side of the display to release the adhesive.
    • If the opening pick gets stuck in the adhesive, "roll" the pick along the side of the iPad, continuing to release the adhesive.
  8. iPad mini 4 LTE Logic Board Replacement: passo 8, imagem 1 %32 iPad mini 4 LTE Logic Board Replacement: passo 8, imagem 2 %32
    • Take the first pick you inserted and slide it up toward the top corner of the iPad.
  9. iPad mini 4 LTE Logic Board Replacement: passo 9, imagem 1 %32
    • Reheat the iOpener and place it on the top edge of the iPad, over the front-facing camera.
    • Be careful not to overheat the iOpener during the repair procedure. Wait at least ten minutes before reheating the iOpener.
    • If you have a flexible iOpener, you can bend it to heat both the upper left corner and the upper edge at the same time.
  10. iPad mini 4 LTE Logic Board Replacement: passo 10, imagem 1 %32 iPad mini 4 LTE Logic Board Replacement: passo 10, imagem 2 %32 iPad mini 4 LTE Logic Board Replacement: passo 10, imagem 3 %32
    • Slide the opening pick around the top left corner of the iPad to separate the adhesive.
  11. iPad mini 4 LTE Logic Board Replacement: passo 11, imagem 1 %32 iPad mini 4 LTE Logic Board Replacement: passo 11, imagem 2 %32 iPad mini 4 LTE Logic Board Replacement: passo 11, imagem 3 %32
    • Slide the opening pick along the top edge of the iPad, stopping just before you reach the camera.
    • As you reach the front-facing camera, pull the pick out slightly and continue sliding it across the top edge.
    • Avoid sliding the opening pick over the front-facing camera, as you may smear adhesive onto the lens or damage the camera. The following steps will detail how to best avoid disturbing the front-facing camera.
  12. iPad mini 4 LTE Logic Board Replacement: passo 12, imagem 1 %32 iPad mini 4 LTE Logic Board Replacement: passo 12, imagem 2 %32 iPad mini 4 LTE Logic Board Replacement: passo 12, imagem 3 %32
    • Leave the opening pick in the iPad slightly past the front-facing camera.
    • Take a second pick and insert it to the left of the camera, where the first pick just was. Slide it back to the corner to completely cut any remaining adhesive.
    • Leave the second pick in place to prevent the corner adhesive from re-sealing as it cools.
  13. iPad mini 4 LTE Logic Board Replacement: passo 13, imagem 1 %32 iPad mini 4 LTE Logic Board Replacement: passo 13, imagem 2 %32
    • Insert the previous pick deeper into the iPad and slide it away from the camera toward the corner.
  14. iPad mini 4 LTE Logic Board Replacement: passo 14, imagem 1 %32
    • Leave the three picks in the corners of the iPad to prevent re-adhering of the front panel adhesive.
    • Reheat the iOpener and place it on the remaining long side of the iPad—along the volume and lock buttons.
  15. iPad mini 4 LTE Logic Board Replacement: passo 15, imagem 1 %32 iPad mini 4 LTE Logic Board Replacement: passo 15, imagem 2 %32 iPad mini 4 LTE Logic Board Replacement: passo 15, imagem 3 %32
    • Insert a new opening pick and slide it down the right edge of the iPad, releasing the adhesive as you go.
  16. iPad mini 4 LTE Logic Board Replacement: passo 16, imagem 1 %32 iPad mini 4 LTE Logic Board Replacement: passo 16, imagem 2 %32 iPad mini 4 LTE Logic Board Replacement: passo 16, imagem 3 %32
    • Continue sliding the opening pick down the right edge of the iPad, reheating the edge using an iOpener if necessary.
    • Be careful not to slice too deep near the bottom right corner, or you risk damaging the display cable.
  17. iPad mini 4 LTE Logic Board Replacement: passo 17, imagem 1 %32
    • Leave the opening picks in place and reheat the iOpener.
    • Remember not to overheat the iOpener—no more than once every ten minutes.
    • Set the reheated iOpener on the home button end of the iPad and let it rest for a few minutes to soften the adhesive beneath the glass.
  18. iPad mini 4 LTE Logic Board Replacement: passo 18, imagem 1 %32 iPad mini 4 LTE Logic Board Replacement: passo 18, imagem 2 %32 iPad mini 4 LTE Logic Board Replacement: passo 18, imagem 3 %32
    • Insert a new opening pick at the bottom right corner of the display, below the last opening pick you used to slice down the right edge.
    • Rotate the new pick around the lower right corner of the device.
  19. iPad mini 4 LTE Logic Board Replacement: passo 19, imagem 1 %32 iPad mini 4 LTE Logic Board Replacement: passo 19, imagem 2 %32
    • Slide the pick from the bottom right corner along the lower edge of the device. Stop about half an inch shy of the home button.
  20. iPad mini 4 LTE Logic Board Replacement: passo 20, imagem 1 %32 iPad mini 4 LTE Logic Board Replacement: passo 20, imagem 2 %32
    • Insert a final opening pick at the lower left corner of the iPad, directly below the existing one.
  21. iPad mini 4 LTE Logic Board Replacement: passo 21, imagem 1 %32 iPad mini 4 LTE Logic Board Replacement: passo 21, imagem 2 %32
    • Slide the pick around the lower left edge of the iPad.
  22. iPad mini 4 LTE Logic Board Replacement: passo 22, imagem 1 %32 iPad mini 4 LTE Logic Board Replacement: passo 22, imagem 2 %32 iPad mini 4 LTE Logic Board Replacement: passo 22, imagem 3 %32
    • Continue sliding the pick at the lower left edge of the display toward the center of the iPad, until it is roughly half an inch from the home button.
  23. iPad mini 4 LTE Logic Board Replacement: passo 23, imagem 1 %32 iPad mini 4 LTE Logic Board Replacement: passo 23, imagem 2 %32 iPad mini 4 LTE Logic Board Replacement: passo 23, imagem 3 %32
    • Twist the two picks at the top edge of the iPad to break up the last of the adhesive holding the display assembly in place.
    • Lift the display from the top edge to open the device.
  24. iPad mini 4 LTE Logic Board Replacement, Battery Connector: passo 24, imagem 1 %32
    • To avoid stressing any cables, hold the display assembly perpendicular to the body of the iPad until it is disconnected.
    • Remove the four 1.2 mm Phillips screws over the battery/display connector bracket.
  25. iPad mini 4 LTE Logic Board Replacement: passo 25, imagem 1 %32
    • Remove the battery/display cable bracket.
  26. iPad mini 4 LTE Logic Board Replacement: passo 26, imagem 1 %32 iPad mini 4 LTE Logic Board Replacement: passo 26, imagem 2 %32
    • When disconnecting any press connectors from the logic board, be sure to lift the connector straight up to avoid ripping the socket off the board.
    • Use the flat tip of a spudger to disconnect the battery connector from its socket on the logic board.
    • Bend the battery connector ribbon cable up slightly to prevent it from making contact and powering on the iPad.
  27. iPad mini 4 LTE Logic Board Replacement, Display Assembly: passo 27, imagem 1 %32 iPad mini 4 LTE Logic Board Replacement, Display Assembly: passo 27, imagem 2 %32 iPad mini 4 LTE Logic Board Replacement, Display Assembly: passo 27, imagem 3 %32
    • Use the pointed end of a spudger to disconnect the display data connector from its socket on the logic board.
    • Use the pointed end of a spudger to disconnect the digitizer cable connector from its socket on the logic board.
    • When reconnecting these, press down from one end of the connector to the other. If you press in the middle of the connector, you may bend it, causing damage or a poor connection.
  28. iPad mini 4 LTE Logic Board Replacement: passo 28, imagem 1 %32
    • Remove the display assembly.
    • To reinstall your display assembly, you will need to replace the display adhesive. Use our display adhesive application guide to reapply your display adhesive and reseal your device.
  29. iPad mini 4 LTE Logic Board Replacement, Upper Component Bracket: passo 29, imagem 1 %32 iPad mini 4 LTE Logic Board Replacement, Upper Component Bracket: passo 29, imagem 2 %32
    • Run the pointed end of a spudger between the looped tape and the plastic cellular antenna housing to make it easier to peel the tape up.
  30. iPad mini 4 LTE Logic Board Replacement: passo 30, imagem 1 %32 iPad mini 4 LTE Logic Board Replacement: passo 30, imagem 2 %32 iPad mini 4 LTE Logic Board Replacement: passo 30, imagem 3 %32
    • Use tweezers to peel up the looped tape adhered over the upper component cable bracket.
  31. iPad mini 4 LTE Logic Board Replacement: passo 31, imagem 1 %32
    • Remove the following four Phillips screws holding the upper component bracket in place:
    • Two 2.1 mm screws
    • Two 1.2 mm screws
  32. iPad mini 4 LTE Logic Board Replacement: passo 32, imagem 1 %32
    • Remove the upper component cable bracket.
  33. iPad mini 4 LTE Logic Board Replacement, Logic Board: passo 33, imagem 1 %32 iPad mini 4 LTE Logic Board Replacement, Logic Board: passo 33, imagem 2 %32 iPad mini 4 LTE Logic Board Replacement, Logic Board: passo 33, imagem 3 %32
    • Press a paper clip or SIM eject tool into the SIM eject hole.
    • Remove the SIM card tray.
  34. iPad mini 4 LTE Logic Board Replacement: passo 34, imagem 1 %32 iPad mini 4 LTE Logic Board Replacement: passo 34, imagem 2 %32
    • Use a spudger to disconnect the upper antenna interconnect cable from its socket on the logic board.
    • Lift the cable connector straight up from the board, do not pry on the socket itself.
  35. iPad mini 4 LTE Logic Board Replacement: passo 35, imagem 1 %32 iPad mini 4 LTE Logic Board Replacement: passo 35, imagem 2 %32 iPad mini 4 LTE Logic Board Replacement: passo 35, imagem 3 %32
    • Peel the upper antenna interconnect cable up off the logic board.
  36. iPad mini 4 LTE Logic Board Replacement: passo 36, imagem 1 %32 iPad mini 4 LTE Logic Board Replacement: passo 36, imagem 2 %32 iPad mini 4 LTE Logic Board Replacement: passo 36, imagem 3 %32
    • Use the flat end of a spudger to lift the rear-facing camera cable connector from its socket on the logic board.
    • Lift the sensor cable connector from its socket.
    • Disconnect the right cellular antenna from the logic board.
  37. iPad mini 4 LTE Logic Board Replacement: passo 37, imagem 1 %32 iPad mini 4 LTE Logic Board Replacement: passo 37, imagem 2 %32 iPad mini 4 LTE Logic Board Replacement: passo 37, imagem 3 %32
    • Use the flat end of a spudger to disconnect the front-facing camera press connector.
    • Lift the Facetime camera ribbon cable out of the way and disconnect the headphone jack ribbon cable directly underneath it.
  38. iPad mini 4 LTE Logic Board Replacement: passo 38, imagem 1 %32
    • Remove the 1.2 mm Phillips screw securing the volume control cable.
  39. iPad mini 4 LTE Logic Board Replacement: passo 39, imagem 1 %32
    • Remove the volume control cable bracket.
  40. iPad mini 4 LTE Logic Board Replacement: passo 40, imagem 1 %32 iPad mini 4 LTE Logic Board Replacement: passo 40, imagem 2 %32
    • Use the point of a spudger to lift the volume control cable connector from its socket on the logic board.
    • Be careful to lift up only on the connector itself, not the socket on the logic board.
  41. iPad mini 4 LTE Logic Board Replacement: passo 41, imagem 1 %32 iPad mini 4 LTE Logic Board Replacement: passo 41, imagem 2 %32
    • Use the point of a spudger to disconnect the two lower antenna interconnect cable connectors.
    • Lift the cables straight up from the board, do not pry on the sockets on the logic board.
    • The longer cable will reconnect to the socket nearest the SIM card slot. The shorter cable connects to the socket nearest the display cable connectors.
  42. iPad mini 4 LTE Logic Board Replacement: passo 42, imagem 1 %32 iPad mini 4 LTE Logic Board Replacement: passo 42, imagem 2 %32
    • Remove any tape covering the ZIF connectors near the Lightning connector port.
  43. iPad mini 4 LTE Logic Board Replacement: passo 43, imagem 1 %32 iPad mini 4 LTE Logic Board Replacement: passo 43, imagem 2 %32 iPad mini 4 LTE Logic Board Replacement: passo 43, imagem 3 %32
    • Use the tip of a spudger to lift each of the two ZIF connector retaining flaps.
  44. iPad mini 4 LTE Logic Board Replacement: passo 44, imagem 1 %32 iPad mini 4 LTE Logic Board Replacement: passo 44, imagem 2 %32
    • Pull each speaker cable out from its ZIF socket.
  45. iPad mini 4 LTE Logic Board Replacement: passo 45, imagem 1 %32 iPad mini 4 LTE Logic Board Replacement: passo 45, imagem 2 %32
    • Peel the lower antenna interconnect cables away from the corner of the rear case.
  46. iPad mini 4 LTE Logic Board Replacement: passo 46, imagem 1 %32 iPad mini 4 LTE Logic Board Replacement: passo 46, imagem 2 %32
    • Peel the left antenna interconnect cable up off the Lightning port cable.
  47. iPad mini 4 LTE Logic Board Replacement: passo 47, imagem 1 %32
    • Remove the four 1.5 mm Phillips screws securing the Lightning port to the rear case.
  48. iPad mini 4 LTE Logic Board Replacement: passo 48, imagem 1 %32 iPad mini 4 LTE Logic Board Replacement: passo 48, imagem 2 %32
    • Begin to gently lift the Lightning connector cable up.
  49. iPad mini 4 LTE Logic Board Replacement: passo 49, imagem 1 %32 iPad mini 4 LTE Logic Board Replacement: passo 49, imagem 2 %32 iPad mini 4 LTE Logic Board Replacement: passo 49, imagem 3 %32
    • Use an opening pick to separate the adhesive connecting the lightning connector cable to the iPad case.
    • If you push with pick too hard, or slip, you could sever the Lightning port cable.
    • You should not need a lot of force, if you are struggling, reapply an iOpener to the back of the case to warm the adhesive.
  50. iPad mini 4 LTE Logic Board Replacement: passo 50, imagem 1 %32 iPad mini 4 LTE Logic Board Replacement: passo 50, imagem 2 %32
    • Continue to slide the pick under the Lightning port cable until you reach the end of the logic board.
    • Leave the pick in place to prevent the adhesive from re-adhering.
  51. iPad mini 4 LTE Logic Board Replacement: passo 51, imagem 1 %32 iPad mini 4 LTE Logic Board Replacement: passo 51, imagem 2 %32
    • Bend back the battery connector over the battery, out of the way of the logic board.
    • Be very careful in the following steps not to sever any cables.
  52. iPad mini 4 LTE Logic Board Replacement: passo 52, imagem 1 %32
    • Reheat an iOpener and lay it on the backside of the iPad near the SIM slot for at least two minutes.
  53. iPad mini 4 LTE Logic Board Replacement: passo 53, imagem 1 %32
    • Once the adhesive has softened, carefully push the opening pick under the logic board.
    • Be very cautious and patient as you pry, do not sever the battery cable, antenna cable, or Lightning port cable.
  54. iPad mini 4 LTE Logic Board Replacement: passo 54, imagem 1 %32 iPad mini 4 LTE Logic Board Replacement: passo 54, imagem 2 %32
    Plastic Cards
    $2.99
    Comprar
    • Once the opening pick has lifted a corner of the logic board, you can insert a plastic card under the board.
    • Slide the plastic card under the logic board, toward the top of the iPad, near the cameras.
    • If the logic board adhesive provides too much resistance, reheat your iOpener and lay it on the rear case to soften the glue.
  55. iPad mini 4 LTE Logic Board Replacement: passo 55, imagem 1 %32 iPad mini 4 LTE Logic Board Replacement: passo 55, imagem 2 %32 iPad mini 4 LTE Logic Board Replacement: passo 55, imagem 3 %32
    • Insert a second plastic card underneath the first one.
    • It's easiest to lead with the corner of the plastic card, then slide the long edge underneath the logic board.
    • Slide the second plastic card up to the top edge of the logic board.
  56. iPad mini 4 LTE Logic Board Replacement: passo 56, imagem 1 %32 iPad mini 4 LTE Logic Board Replacement: passo 56, imagem 2 %32
    • Lift up on the edges of both plastic cards to pry the logic board from the rear case.
  57. iPad mini 4 LTE Logic Board Replacement: passo 57, imagem 1 %32
    • Remove the logic board assembly from the rear case.
    • If you are replacing your logic board with a new part, be sure the parts match identically, you may need to transfer additional components.
    • iPad mini 4 logic boards are paired to their home buttons, if you replace your logic board, you will no longer have Touch ID functionality.
Conclusão
7 outras pessoas executaram este guia.
Evan Noronha
Membro desde: 02/05/15
223.466 Reputação
Autoria de 168 guias
Um comentário
This guide needs amending urgently before more people destroy their LCD displays by cutting through the tape holding the backlight to the LCD glass, or pushing a pick or other tool between the LCD glass and touchscreen glass.
The guide states:
Don't insert the opening pick any deeper than the black bezel on the side of the display.
This is WRONG and will destroy your display. The black bezel is 5mm wide, this is beyond the 1mm wide adhesive and into the LCD display and backlight assembly. Do not insert anything more than 2mm down the sides of the display.
Any further than 2mm and, like me, you will be looking at a very expensive LCD display replacement.
Thanks IFIXIT.COM for publishing an incorrect guide that has destroyed my display.
jamesqb2001 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 7
Últimos 7 dias: 20
Últimos 30 dias: 109
Duração total: 12,330
