Ir para o conteúdo principal
Introdução
prereq only guide for replacing a screen and digitizer, or home button.
  1. Use the pointed end of a spudger to disconnect the display data connector from its socket on the logic board. Use the pointed end of a spudger to disconnect the digitizer cable connector from its socket on the logic board. When reconnecting these, press down from one end of the connector to the other. If you press in the middle of the connector, you may bend it, causing damage or a poor connection.
    • Use the pointed end of a spudger to disconnect the display data connector from its socket on the logic board.
    • Use the pointed end of a spudger to disconnect the digitizer cable connector from its socket on the logic board.
    • When reconnecting these, press down from one end of the connector to the other. If you press in the middle of the connector, you may bend it, causing damage or a poor connection.
  2. Remove the display assembly.
    • Remove the display assembly.
    • To reinstall your display assembly, you will need to replace the display adhesive. Use our display adhesive application guide to reapply your display adhesive and reseal your device.
Conclusão
Evan Noronha
Membro desde: 05/02/2015
206.324 Reputação
178 Guias de autoria
Equipe
iFixit Membro de iFixit
Community
136 Membros
15.992 Guias de autoria
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 6
Duração total: 192
