Introdução
Couldn't find a guide to fix a customers iPad so here it is put alot of work into Providing something you can use a reference! Thanks comment please!
Ferramentas
Nenhuma ferramenta especificada.
Peças
Be Sure to turn off iPad by pressing and release the volume up button then volume down.
While Pressing and holding side button until screen turns off.
Just use the slider if you can.
14 outras pessoas concluíram este guia.
13 comentários
My Face ID no longer works?
Most likely you may have damaged the flex of proximity sensor.
Check connector
Check placement with flash light make sure everything is aligned correctly
What size of that tape do you need for this iPad? Thanks
