Ir para o conteúdo principal
iPad Pro 12.9" 2nd gen Screen Replacement
O que você precisa
    • Follow this video guide from start to finish and enjoy!
Conclusão
Did you follow all the steps? Yes! Then enjoy!
14 outras pessoas executaram este guia.
Fix It Planet
Membro desde: 05/29/15
1.561 Reputação
Autoria de 3 guias
5 comentários
Kann man beim 12.9 Gen2 NUR das Glas tauschen? Das display geht 1a aber ich habe mehrere risse auf dem schutzglas. Möchte nicht dafür auch das display tauschen…..
sim sem - Responder
@simsem I'm wondering the same thing. Did you find out if it was possible ? Is the glass reparable without changing the whole screen itself ?
Shldnet -
If you get the replacement screen with daughterboard attached you don’t need to solder anything.
Gregg Stanley - Responder
That is correct …. but if you solder it on yourself you reuse the original daughter board instead of throwing it away and save some money to boot. Seems reasonable if you can do it.
Fix It Planet -
I replaced the screen but it the touch screen is randomly unresponsive at times. Mostly on the middle right of the screen. I would have to touch same area couple of times for it to response. The unit is on the latest iOS 15.1. Any thoughts?
Chio Phanh - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 6
Últimos 7 dias: 53
Últimos 30 dias: 221
Duração total: 41,650
