Ir para o conteúdo principal
    • Follow this video guide from start to finish and enjoy!
Conclusão
Did you follow all the steps? Yes! Then enjoy!
14 outras pessoas concluíram este guia.
Fix It Planet
Membro desde: 29/05/2015
1.501 Reputação
3 Guias de autoria
4 comentários
Kann man beim 12.9 Gen2 NUR das Glas tauschen? Das display geht 1a aber ich habe mehrere risse auf dem schutzglas. Möchte nicht dafür auch das display tauschen…..
sim sem - Responder
If you get the replacement screen with daughterboard attached you don’t need to solder anything.
Gregg Stanley - Responder
That is correct …. but if you solder it on yourself you reuse the original daughter board instead of throwing it away and save some money to boot. Seems reasonable if you can do it.
Fix It Planet -
I replaced the screen but it the touch screen is randomly unresponsive at times. Mostly on the middle right of the screen. I would have to touch same area couple of times for it to response. The unit is on the latest iOS 15.1. Any thoughts?
Chio Phanh - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 34
Últimos 7 dias: 228
Últimos 30 dias: 782
Duração total: 31,437
