Ir para o conteúdo principal
iPad Pro 11" Screen Cable Replacement
Pré-requisito somente
Este é um guia somente para pré-requisitos! Este guia faz parte de outro procedimento e não deve ser usado sozinho.
O que você precisa
  1. iPad Pro 11" Screen Cable Replacement, Display cable information: passo 1, imagem 1 %32 iPad Pro 11" Screen Cable Replacement, Display cable information: passo 1, imagem 2 %32
    • If your replacement screen didn't come with the two removable display cables, follow the next six steps to remove and transfer these cables.
    • The display cable connectors are located under a bracket near the bottom right corner of the screen.
  2. iPad Pro 11" Screen Cable Replacement, Separate the non-removable display cable: passo 2, imagem 1 %32 iPad Pro 11" Screen Cable Replacement, Separate the non-removable display cable: passo 2, imagem 2 %32 iPad Pro 11" Screen Cable Replacement, Separate the non-removable display cable: passo 2, imagem 3 %32
    • Slide an opening pick under the non-removable display cable to loosen it from the bracket.
  3. iPad Pro 11" Screen Cable Replacement, Unfasten the display cable bracket: passo 3, imagem 1 %32 iPad Pro 11" Screen Cable Replacement, Unfasten the display cable bracket: passo 3, imagem 2 %32
    • Use a Phillips screwdriver to remove the two 1.2 mm screws securing the display cable bracket.
  4. iPad Pro 11" Screen Cable Replacement, Remove the display cable bracket: passo 4, imagem 1 %32 iPad Pro 11" Screen Cable Replacement, Remove the display cable bracket: passo 4, imagem 2 %32
    • Remove the display cable bracket.
  5. iPad Pro 11" Screen Cable Replacement, Disconnect and remove the display cables: passo 5, imagem 1 %32 iPad Pro 11" Screen Cable Replacement, Disconnect and remove the display cables: passo 5, imagem 2 %32 iPad Pro 11" Screen Cable Replacement, Disconnect and remove the display cables: passo 5, imagem 3 %32
    • Use the flat end of a spudger to pry up and disconnect the narrow display cable.
    • Remove the narrow display cable. Set it aside for reassembly.
  6. iPad Pro 11" Screen Cable Replacement: passo 6, imagem 1 %32 iPad Pro 11" Screen Cable Replacement: passo 6, imagem 2 %32 iPad Pro 11" Screen Cable Replacement: passo 6, imagem 3 %32
    • Disconnect and remove the wide display cable. Set it aside for reassembly.
Conclusão
Chayton Ritter
Membro desde: 08/21/20
25.153 Reputação
Autoria de 105 guias
Equipe
Guide Team Membro de Guide Team
Staff
10 Membros
Autoria de 15.957 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Ao todo: 86
