Ir para o conteúdo principal
iPad Mini Home button Replacement
O que você precisa
  1. iPad Mini Home button Replacement, Reveal solder pads: passo 1, imagem 1 %32
    • Use heat to losen the adhesive. A low temp hot air gun will suffice.
    • After heating up the adhesive, you can use a basic spudger to pry off the flex from the glass
    • be sure not to use too much force, this flex is very fragile.
  2. iPad Mini Home button Replacement, Apply your own solder: passo 2, imagem 1 %32
    • use your iron, and low guage solder to apply a layer of your own solder on the pads
    • the new solder will allow for faster, and more controlled heat transfer.
  3. iPad Mini Home button Replacement, Remove the flex: passo 3, imagem 1 %32
    • a few back and forth strokes of your soldering iron should be enough to remove the flex cable.
    • be sure not to apply too much force with the iron, as you can cause physical damage to the pads.
    • Using a little bit of solder flux, can help decrease the amount of pressure needed to properly transfer the heat.
  4. iPad Mini Home button Replacement, Line up the pads: passo 4, imagem 1 %32
    • be sure to make sure you can see directly through the holes marked on both sides.
    • Line the corrisponding holes up, and make sure they are 100% overlapped.
    • failing to properly line up the holes can cause a short, or cold circuit.
  5. iPad Mini Home button Replacement, Re-Solder: passo 5, imagem 1 %32
    • Use the new solder you added, to connect to the flex.
    • be sure to cover the traces with some electrical tape to avoid shorts.
    • congratulations on your home button replacement
Linha de Chegada
3 outras pessoas executaram este guia.
Scott
Membro desde: 10/09/13
9.901 Reputação
Autoria de 4 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 14
Últimos 30 dias: 69
Ao todo: 12,903
