Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
Prereq for removing the logic board. Battery has been removed.
O que você precisa
Pull the wide tape toward the top of the iPad, applying constant force to release it from the antenna cable between it and the speaker.
Slide the tip of a spudger through the gap between the wide tape and the antenna cable, breaking the adhesive connecting the two.
Continue pulling the wide tape until it is no longer covering the antenna cable.
