Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Peças e ferramentas
Introdução
Prereq for disconnecting battery.
Peças
Nenhum componente especificado.
  1. Remove the three 1.3 mm Phillips #00 screws securing the connector shield to the logic board.
    • Remove the three 1.3 mm Phillips #00 screws securing the connector shield to the logic board.
    • Be sure to not substitute these three screws with any other screws, specifically the screws securing the LCD shield plate to the rear case of the iPad. Any slightly longer screws may strip the screw holes and result in irreparable damage to the logic board.
  2. Kit de pontas universal para chave
    112 bits for every fix.
    Upgrade Your Toolbox
  3. Use a pair of tweezers to grasp and remove the connector shield from the iPad.
    • Use a pair of tweezers to grasp and remove the connector shield from the iPad.
  4. Use a plastic opening tool to gently pry the battery connector up from its socket on the logic board. Be very careful to only pry up on the battery connector and not on the socket itself. If you pry up on the logic board socket, you may break the connector entirely.
    • Use a plastic opening tool to gently pry the battery connector up from its socket on the logic board.
    • Be very careful to only pry up on the battery connector and not on the socket itself. If you pry up on the logic board socket, you may break the connector entirely.
Conclusão
Andrew Optimus Goldheart
Membro desde: 17-10-2009
444.937 Reputação
411 Guias de autoria
Equipe
iFixit Membro de iFixit
Community
115 Membros
11.168 Guias de autoria
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Duração total: 360
