Ir para o conteúdo principal
iPad Mini 2 Wi-Fi Front Panel Replacement
Pré-requisito somente
Este guia destina-se apenas a ser usado como pré-requisito para outros guias. É incompleto por si só.
O que você precisa
  1. iPad Mini 2 Wi-Fi Front Panel Replacement, Front Panel: passo 1, imagem 1 %32 iPad Mini 2 Wi-Fi Front Panel Replacement, Front Panel: passo 1, imagem 2 %32
    • Use the flat end of a spudger to lift the digitizer cable connector straight up off of its socket.
    • Be careful as you lift the connector from the socket—the pins in the socket are extremely fragile and can easily break!
    During reassembly at this point, be very careful to line up both sides of the connector. I came very close to destroying the digitizer cable connectors because I wasn't paying attention.
    Jeff G - Responder
    I learned the hard way that we should be lifting from the short side of the connector, not the long side as shown here. The gold pins inside the FPC socket are very fragile and more likely to break when lifted as shown in this picture.
    Frank Buccella - Responder
    Yes, I just learned that lesson as well. IMO a bit too ridiculously fragile.
    Daniel - Responder
    Hi, i just broke this micro pins… it’s extremely fragile. Whats the name and were i can found a replacement to this connector? I ll try to find a friend that have a equipment for soldering this…
    Leonardo Marques de Souza - Responder
  2. iPad Mini 2 Wi-Fi Front Panel Replacement: passo 2, imagem 1 %32 iPad Mini 2 Wi-Fi Front Panel Replacement: passo 2, imagem 2 %32 iPad Mini 2 Wi-Fi Front Panel Replacement: passo 2, imagem 3 %32
    • Slide the spudger under the battery side of the digitizer board to begin separating it from the rear case.
    • Lift the digitizer board up to free the last of the adhesive.
  3. iPad Mini 2 Wi-Fi Front Panel Replacement: passo 3, imagem 1 %32
    • Lift and remove the front panel from the iPad.
Conclusão
10 outras pessoas executaram este guia.
Sam Goldheart
Membro desde: 10/18/12
465.762 Reputação
Autoria de 538 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 135
Autoria de 16.817 guias
2 comentários
I'll give this quide a 3/5. The problem is the end where you just say reverse the steps. That is an easy out that too many people use. There are important things to do when re-assembling that are not pointed out that may come back to bite you just attempting to reverse the steps. I do like the stepped pictures showing before and after views. Overall the process is not that bad other than removing the broken glass which breaks a lot more as you go. A hair dryer on high worked fine for warming up the glue, you just need to be aware of cleaning the area of glass bits before turning it on. Glad I didn't pay somebody big bucks to do this job.
italternatives - Responder
Due reassebling its really important to bend the digitizer cable with a spudger inside the case. If you just press the Front down the cable will be between adhensive and case. So near the home button, it won't fit very well!!
itf7o - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 6,525
