Ir para o conteúdo principal
iPad Mini 2 Wi-Fi Front Panel Replacement
Pré-requisito somente
Este guia destina-se apenas a ser usado como pré-requisito para outros guias. É incompleto por si só.
O que você precisa
  1. iPad Mini 2 Wi-Fi Front Panel Replacement, Front Panel: passo 1, imagem 1 %32 iPad Mini 2 Wi-Fi Front Panel Replacement, Front Panel: passo 1, imagem 2 %32
    • Use the flat end of a spudger to lift the digitizer cable connector straight up off of its socket.
    • Be careful as you lift the connector from the socket—the pins in the socket are extremely fragile and can easily break!
  2. iPad Mini 2 Wi-Fi Front Panel Replacement: passo 2, imagem 1 %32 iPad Mini 2 Wi-Fi Front Panel Replacement: passo 2, imagem 2 %32 iPad Mini 2 Wi-Fi Front Panel Replacement: passo 2, imagem 3 %32
    • Slide the spudger under the battery side of the digitizer board to begin separating it from the rear case.
    • Lift the digitizer board up to free the last of the adhesive.
  3. iPad Mini 2 Wi-Fi Front Panel Replacement: passo 3, imagem 1 %32
    • Lift and remove the front panel from the iPad.
Conclusão
10 outras pessoas executaram este guia.
Sam Goldheart
Membro desde: 10/18/12
465.777 Reputação
Autoria de 538 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 135
Autoria de 16.817 guias
2 comentários
I'll give this quide a 3/5. The problem is the end where you just say reverse the steps. That is an easy out that too many people use. There are important things to do when re-assembling that are not pointed out that may come back to bite you just attempting to reverse the steps. I do like the stepped pictures showing before and after views. Overall the process is not that bad other than removing the broken glass which breaks a lot more as you go. A hair dryer on high worked fine for warming up the glue, you just need to be aware of cleaning the area of glass bits before turning it on. Glad I didn't pay somebody big bucks to do this job.
italternatives - Responder
Due reassebling its really important to bend the digitizer cable with a spudger inside the case. If you just press the Front down the cable will be between adhensive and case. So near the home button, it won't fit very well!!
itf7o - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 6,525
