Ir para o conteúdo principal
iPad 6 Wi-Fi Front Panel Assembly Replacement
Pré-requisito somente
Este guia destina-se apenas a ser usado como pré-requisito para outros guias. É incompleto por si só.
O que você precisa
  1. iPad 6 Wi-Fi Front Panel Assembly Replacement, Front Panel Assembly: passo 1, imagem 1 %32 iPad 6 Wi-Fi Front Panel Assembly Replacement, Front Panel Assembly: passo 1, imagem 2 %32
    • Remove any tape covering the home button ribbon cable connector.
  2. iPad 6 Wi-Fi Front Panel Assembly Replacement: passo 2, imagem 1 %32 iPad 6 Wi-Fi Front Panel Assembly Replacement: passo 2, imagem 2 %32 iPad 6 Wi-Fi Front Panel Assembly Replacement: passo 2, imagem 3 %32
    • Use the flat end of a spudger to flip the tab on the home button ribbon cable ZIF connector upward.
    • Carefully pull the home button ribbon cable straight out of the ZIF connector.
  3. iPad 6 Wi-Fi Front Panel Assembly Replacement: passo 3, imagem 1 %32 iPad 6 Wi-Fi Front Panel Assembly Replacement: passo 3, imagem 2 %32 iPad 6 Wi-Fi Front Panel Assembly Replacement: passo 3, imagem 3 %32
    • Use a the flat end of a spudger or a fingernail to carefully pop the two digitizer cable connectors straight up from their sockets.
    • To avoid damaging your iPad, pry only on the connectors themselves, not on the socket on the logic board.
    • During reassembly, make sure that these connectors are completely seated in their sockets, or you may encounter display issues.
  4. iPad 6 Wi-Fi Front Panel Assembly Replacement: passo 4, imagem 1 %32 iPad 6 Wi-Fi Front Panel Assembly Replacement: passo 4, imagem 2 %32
    • Carefully peel the home button ribbon cable up off of the adhesive holding it to the rear case.
  5. iPad 6 Wi-Fi Front Panel Assembly Replacement: passo 5, imagem 1 %32 iPad 6 Wi-Fi Front Panel Assembly Replacement: passo 5, imagem 2 %32
    Ferramenta utilizada neste passo:
    Polyimide Tape
    $9.99
    • Remove the front panel assembly.
    • If you experience "ghost" or "phantom" touch input issues with your new display, this can be resolved by adding a layer of very thin insulating tape, such as Kapton (polyimide) tape, to the highlighted areas on the back of the panel. iFixit panels come with the proper insulation, and should not require the addition of any tape.
    • Without the proper insulation, these areas of the digitizer can ground out against other components, causing touch input malfunction.
    • The insulation is not visible to the naked eye, and is different from the foam dust barrier strips found on many iPads.
Conclusão
Uma outra pessoa concluiu este guia.
Sam Goldheart
Membro desde: 10/18/12
471.877 Reputação
Autoria de 538 guias
Equipe
iFixit Membro de iFixit
Staff
118 Membros
Autoria de 19.643 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 16
Ao todo: 171
