Ir para o conteúdo principal
iPad 4 CDMA Home Button Control Board Replacement
Pré-requisito somente
Este é um guia somente para pré-requisitos! Este guia faz parte de outro procedimento e não deve ser usado sozinho.
O que você precisa
  1. iPad 4 CDMA Home Button Control Board Replacement, Home Button Control Board: passo 1, imagem 1 %32
    • Remove the two 2.1 mm Phillips #00 Phillips screws securing the home button control board to the home button mounting bracket.
  2. iPad 4 CDMA Home Button Control Board Replacement: passo 2, imagem 1 %32 iPad 4 CDMA Home Button Control Board Replacement: passo 2, imagem 2 %32
    • Wedge the flat edge of a plastic opening tool in between the right end of the home button control board and the home button mounting bracket.
    • Depress the plastic opening tool downwards to pry the adhesive securing the home button control board from the home button mounting bracket.
    • Repeat the procedure to release the adhesive underneath the left end of the home button control board.
  3. iPad 4 CDMA Home Button Control Board Replacement: passo 3, imagem 1 %32
    • Lift and remove the home button control board up off the home button mounting bracket.
  4. iPad 4 CDMA Home Button Control Board Replacement: passo 4, imagem 1 %32 iPad 4 CDMA Home Button Control Board Replacement: passo 4, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Use the flat edge of a spudger to scrape the old adhesive off the bottom right corner of the front panel assembly.
    • If necessary, gently peel the old adhesive with a pair of tweezers.
  5. iPad 4 CDMA Home Button Control Board Replacement: passo 5, imagem 1 %32 iPad 4 CDMA Home Button Control Board Replacement: passo 5, imagem 2 %32
    • Gently place the home button control board on top of the home button mounting bracket.
    • Make sure the home button control board is lined up with the bottom of the home button mounting bracket.
  6. iPad 4 CDMA Home Button Control Board Replacement: passo 6, imagem 1 %32
    • Insert the two 2.1 mm Phillips #00 Phillips screws back into the home button control board to secure it against the home button mounting bracket.
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Ao todo: 212
