Ir para o conteúdo principal
Introdução
Use this guide to replace a broken ambient light sensor.
  1. If your display glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping the glass. Lay overlapping strips of clear packing tape over the iPad's display until the whole face is covered. This will keep glass shards contained and provide structural integrity when prying and lifting the display.
    • Lay overlapping strips of clear packing tape over the iPad's display until the whole face is covered.
    • Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
    • Wear safety glasses to protect your eyes, and be careful not to damage the LCD screen.
  2. The iPad shown in the photos may look slightly different from your iPad, but the procedure is the same. Insert a metal spudger between the right edge of the display assembly and the rear panel assembly.
    • The iPad shown in the photos may look slightly different from your iPad, but the procedure is the same.
    • Insert a metal spudger between the right edge of the display assembly and the rear panel assembly.
    • Rotate the spudger away from you to release the tabs along the top edge of the display.
  3. Insert a second metal spudger between the top edge of the display assembly and the rear panel assembly to keep the tabs from snapping back into place. Pry the display assembly away from the rear panel.
    • Insert a second metal spudger between the top edge of the display assembly and the rear panel assembly to keep the tabs from snapping back into place.
    • Pry the display assembly away from the rear panel.
  4. Continue prying the display assembly away from the rear panel along the bottom and left edges of the iPad. Use extreme caution as you approach the top edge of the iPad. The digitizer ribbon cable is located near the edge of the rear panel and can easily be damaged.
    • Continue prying the display assembly away from the rear panel along the bottom and left edges of the iPad.
    • Use extreme caution as you approach the top edge of the iPad. The digitizer ribbon cable is located near the edge of the rear panel and can easily be damaged.
  5. Lift the display assembly away from the rear panel assembly by its bottom edge.
    • Lift the display assembly away from the rear panel assembly by its bottom edge.
    • Do not excessively lift the display assembly off the rest of the iPad, as a fragile antenna cable with very little slack still connects the two components.
  6. Use the flat end of a spudger to pry the antenna connector closest to the bottom of the iPad up off its socket on the communications board.
    • Use the flat end of a spudger to pry the antenna connector closest to the bottom of the iPad up off its socket on the communications board.
  7. In the following steps, you will disconnect the three cables attaching the display assembly to the logic board. The cables are for the following components:
    • In the following steps, you will disconnect the three cables attaching the display assembly to the logic board. The cables are for the following components:
    • Digitizer
    • Ambient Light Sensor
    • Display Data Cable
  8. Use the edge of an iPod opening tool to flip up the retaining flaps holding the digitizer ribbon cables in their sockets on the logic board. Be sure you are flipping up the retaining flap, not the socket itself. Pull the digitizer ribbon cables straight out of their sockets.
    • Use the edge of an iPod opening tool to flip up the retaining flaps holding the digitizer ribbon cables in their sockets on the logic board.
    • Be sure you are flipping up the retaining flap, not the socket itself.
    • Pull the digitizer ribbon cables straight out of their sockets.
  9. Use an iPod opening tool to remove the ambient light sensor connector from its socket by gently prying upward.
    • Use an iPod opening tool to remove the ambient light sensor connector from its socket by gently prying upward.
  10. Disconnect the display data cable from the main board by flipping up the metal retainer by its black plastic pull tab. Pull the cable connector away from its socket.
    • Disconnect the display data cable from the main board by flipping up the metal retainer by its black plastic pull tab.
    • Pull the cable connector away from its socket.
    • Pull the connector parallel to the face of the logic board.
  11. Remove the display assembly from the rear panel assembly.
    • Remove the display assembly from the rear panel assembly.
  12. If necessary, peel the strip of foam tape off the ambient light sensor.
    • If necessary, peel the strip of foam tape off the ambient light sensor.
    • It is not necessary to completely remove the foam tape attached to the antenna.
  13. Use the edge of an iPod opening tool to carefully pry the ambient light sensor board off the adhesive securing it to the display frame. Once you've gained enough clearance, peel the ambient light sensor off the LCD. If necessary, attach the plastic view window to your new ambient light sensor before installation.
    • Use the edge of an iPod opening tool to carefully pry the ambient light sensor board off the adhesive securing it to the display frame.
    • Once you've gained enough clearance, peel the ambient light sensor off the LCD.
    • If necessary, attach the plastic view window to your new ambient light sensor before installation.
Conclusão
14 outras pessoas concluíram este guia.
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 14
Duração total: 34,225
