Ir para o conteúdo principal
iPad 3 Wi-Fi Power & Volume Button Assembly Replacement
Pré-requisito somente
Este é um guia somente para pré-requisitos! Este guia faz parte de outro procedimento e não deve ser usado sozinho.
O que você precisa
  1. iPad 3 Wi-Fi Power & Volume Button Assembly Replacement, Power & Volume Button Assembly: passo 1, imagem 1 %32
    • Remove the following screws securing the power & volume button cable to the aluminum frame:
    • Two 5.5mm Phillips #0
    • One 2.6 mm Phillips #0
    • Two 2.6 mm Phillips #0
    • These screws are angled into the aluminum frame. Be sure to always hold the screwdriver in line with the screw.
  2. iPad 3 Wi-Fi Power & Volume Button Assembly Replacement: passo 2, imagem 1 %32
    • Remove the piece of plastic covering the volume buttons.
  3. iPad 3 Wi-Fi Power & Volume Button Assembly Replacement: passo 3, imagem 1 %32
    • Remove the single 2.6 mm Phillips #00 screw holding the volume button frame to the aluminum frame.
    • This screw is angled into the aluminum frame. Be sure to always hold the screwdriver in line with the screw.
  4. iPad 3 Wi-Fi Power & Volume Button Assembly Replacement: passo 4, imagem 1 %32 iPad 3 Wi-Fi Power & Volume Button Assembly Replacement: passo 4, imagem 2 %32
    • Wedge the edge of a plastic opening tool underneath the sleep/wake sensor, being careful to not damage the fragile cable.
    • Move the plastic opening tool around the sensor, releasing the adhesive.
  5. iPad 3 Wi-Fi Power & Volume Button Assembly Replacement: passo 5, imagem 1 %32 iPad 3 Wi-Fi Power & Volume Button Assembly Replacement: passo 5, imagem 2 %32
    • Continue sliding the plastic opening tool underneath the power & volume cables, releasing the adhesive.
  6. iPad 3 Wi-Fi Power & Volume Button Assembly Replacement: passo 6, imagem 1 %32 iPad 3 Wi-Fi Power & Volume Button Assembly Replacement: passo 6, imagem 2 %32
    • Using the tip of a spudger, release the adhesive underneath the volume button branch of the ribbon cable.
  7. iPad 3 Wi-Fi Power & Volume Button Assembly Replacement: passo 7, imagem 1 %32 iPad 3 Wi-Fi Power & Volume Button Assembly Replacement: passo 7, imagem 2 %32
    • Continue sliding the tip of the spudger toward the top of the iPad, releasing the adhesive.
  8. iPad 3 Wi-Fi Power & Volume Button Assembly Replacement: passo 8, imagem 1 %32 iPad 3 Wi-Fi Power & Volume Button Assembly Replacement: passo 8, imagem 2 %32 iPad 3 Wi-Fi Power & Volume Button Assembly Replacement: passo 8, imagem 3 %32
    • With the tip of the spudger still underneath the ribbon cable, gently lift the power button out of its socket in the aluminum frame.
  9. iPad 3 Wi-Fi Power & Volume Button Assembly Replacement: passo 9, imagem 1 %32 iPad 3 Wi-Fi Power & Volume Button Assembly Replacement: passo 9, imagem 2 %32
    • Holding the power & volume button cable with with both hands, carefully pull the volume buttons and lock switch from their sockets in the aluminum frame.
    • Lift and remove the power & volume button cable out of the rear aluminum case.
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Ao todo: 172
